Trevor started following Coil pack 0.9ltr engine , nissan micra K13 Fault codes , Nissan President 1994 with ACTSUS hydraulic system and 1 other
Michael simpson joined the community
iago joined the community
Gill joined the community
VISSOLTA joined the community
The truck has been sold.
FrankNL joined the community
Spigola joined the community
zippdee joined the community
Johnfleisc joined the community
Trevor started following Clicking noise in reverse and forwards only from wheel.
