  2. JeffMc joined the community
  4. Griffmt10 joined the community
  5. endy joined the community
  6. I own a 2016 Nissan Qashqai and am wondering if it’s possible to add more organised boot storage for tools and travel gear. Has anyone modified the boot layout on this model year, and what solutions worked best?
  7. dradem joined the community
  8. Last week
  9. Hi there I just got my first car... and it is a beast! 2 litre diesel X-Trail Got loads of questions that I'm hoping will have already been answered in the forums. Looking forward to picking up hints and tips :)
  10. Bebop Cowboy joined the community
  11. Hi guys for those with a 2021 Juke Gen II, has anyone upgraded the suspension to improve comfort or reduce body roll? Curious about real world improvements? sam
  12. Thanks for the add My 2024 Qashqai e‑Power sometimes hesitates when accelerating gently between 20–40mph. Has anyone diagnosed the cause, software behaviour, a sensor problem??, or hybrid energy management quirks? Cheers Guys
  13. Isaac joined the community
  14. Sam Deano64 joined the community
  15. Skipper82 joined the community
  16. Dodge Jamie86 joined the community
  17. Jamie76 joined the community
  18. I would be measuring the glow plugs (old and then compare to new) at least so you could identify which cylinder(s) is at fault.
  19. Rhino posted a topic in Nissan Pathfinder Forum
  20. used to see this with black electrical tape. does the job.
  21. Hi Trev . It's " Glow plug fault on circuit A" on my reader .
  22. What fault codes are you getting from the scanner readout?
  23. You could try covering the beam pattern in the correct portion of the headlamp with cardboard (and bluetack) before fitting the stickers. This way you can see if the beam pattern is no longer pointing to the kerb (UK spec lights) and it doesn't necessarily have to deflect it to the other side but just not dazzling the oncoming traffic. This means it may reduce your vision on the kerbside (European spec lights) but at least you are legal.
  24. YES! Night ferry ....
  25. Earlier
  26. Hello everyone , I'm Steve, a new member & would appreciate any help with my 1.6 dci 2012 qashqai. my obd reader indicated a faulty circuit A , I replaced all glow plugs , but problem persists , long cranking especially in cold weather , to start the car . I gather the relay or fuse may be responsible , but unsure of there location & accessibility . Any help appreciated ! Thanks
  27. this is for a campervan but has some good points
  28. will you be driving at night?
  29. Thanks for replying! Um, yes, I got square eyes looking on Youtube and found nothing. Hence my message on here. 🙅‍♀️
  30. Hi Rose Are you likely to be driving at night? If yes then they should go on the nearside (passenger side) but yes your right, its not easy. I drive without them as I have flat LED but if you want to be legal then stick them on. Have you tried Youtube?
  31. Hi folks! I'm driving to France so need to put on some beam deflectors on my Qashqai 2021. I've bought Eurolites, and having read the instructions I understand that I need to apply them using picture 146 but to be honest, I really don't understand where to stick them! (Also they're not the same position on both lights 🙄) . I've been looking, but can't find, any photos of beam deflectors on Qashqais so I can copy. Can anyone help?? Am I the only one who finds this difficult? Any advice gratefully received. TY
  32. I need rear brake adjusters for my 85 Stanza hatchback, its a T-11
  33. Hi
    Welcome to the club @Rhino
  34. Hi
  35. Trevor started following Micra Business 2022 and Hi
  36. Hi
  37. Hi Trevor, thanks for your suggestion. I'm not all that savvy with this internet thing. I'm with Orange in France. I presume when the Micra is asking for my password they mean the long list of letter and numbers that came with my love of. I have had to use that to get the internet on my tablet and laptop . Is there any other password?
  38. Hi...welcome to the Club sounds simplistic - but can't you change your internet password to a shorter one so that the characters fit?
  39. What is the actual issue with the car? Also, is it engine speed or vehicle speed sensor you are looking at?
