  1. Last week
  2. I used Lens on my old Alphard years ago.. worked a treat. once settings set up then let it be.
  3. I would use google lens and translate functions to define which controls do what
  4. Hi....welcome to the Club Please let us know how you get on with it all Good to have you onboard
  5. Hi .... welcome to the Club Nice collection of cars - good to have you onboard
  6. Trex4x4 joined the community
  7. cliff joined the community
  8. Only done 10 miles but loving it already. We did have a Kadjar as a company car for 2 years so I had an idea of what it would be like.
  9. I bought an Elgrand converted to a campervan. Very nice job, but all the controls have Japanese text and the handbook I got doesn't help much. Does anyone know anything about the Elgrand? Thanks David
  10. My daughter, aged 20, bought a Nissan Micra 2022 plate a year ago and it recently came up with some engine warning lights, specifically C1426-04 & P2263. the car's turbo isn't currently working correctly. We took the car to halfords for Daignostics, they took the readings, charged £50 & told us to go to a Nissan Dealer for more thorough investigations. We did this, at a cost of £243 and they have told us that they checked the boost sensor operation - all ok. They "suspect" turbo actuator failed causing ECU corruption and no ECU update found. They have quoted us £4226.65 for this which will replace the whole turbo & actuator (even though they confirmed that the turbo is actually working) and a new CPU. This just seems scandalous to me that the car is only 3 and half years old and a repair bill of over 50% of the value of the car is needed! Can anyone help on this matter as my daughter doesn't have this cash!
  11. Hi I have a 2017 Nissan Qashqai J11 St auto petrol model. The orange malfunction indicator light has been on for a while now. I have had the vehicle several times to an auto electrician who has reset it and the code was P0303 with the message that the 3rd cylinder is fisfiring. I have also had it to the local Nissan dealer who again reset it with the same error code showing up. It has had a new coil ignition pack put in as well as a standard service with new spark plugs. It has recently started to shudder a bit when driving and the motor has cut out and stopped when I am stationery. It restarts again when I turn it over. I have taken it to another mechanic and they have swapped the 3rd and 4th injectors to see it that would make a difference. The malfunction light has stayed off, however they got me to take the car on a drive at a speed of 100klms to see what happened. In doing this, the light came back on for a few seconds and went off again but the motor cut out again when I stopped at an intersection. They have rescanned it again and it is now showing that the 4th cylinder is fisfiring which indicates that the injector/s need replacing. Just wondering if anyone else has had this situation before and what the outcome was. Thank you. Debbie. Queensland
  12. Not on late models as it an EU requirement as I understand it. Mine is set up with a shortcut to turn audio warning off by pressing control switch and Okay.
  13. Just purchased another Japanese branded car (3rd one) a 2025 Qashqai e-Power with 5200 miles on the clock (ex demo from main dealer). First one built here in the UK - the Mazda 6 and Honda Accord both shipped to the UK. The later two proved ultra reliable so we'll see how built in Britain goes - well I hope! Any tips on economical driving techniques for e-Power would be appreciate. TIA
  14. LAL posted a topic in Nissan Pathfinder Forum
  15. I’m a former owner of three 280Z cars. Although I’ve also owned early Porsche 356a, 356c and 911 cars, the Z cars rank highest in my heart. Now the owner of. 2012 Nissan Rogue and it has all of the issues that it is famous for - but I refuse to give up. So, I will be questioning the forum regarding my CVT repair attempts, codes and results. Here goes!!
  16. Sueh joined the community
  17. Earlier
  18. welcome to the club !!
  19. Enjoy the Qashqai!! im sure it will be better than the note!
  20. Picking up my new to me Qashqai on Saturday. It's a 2017 1.5 dci Tekna. Previous car was a Nissan Note that, for various reasons, I was never happy with ! 🤷
  21. Indym500 joined the community
  22. DaRo joined the community
  23. Hello from Denmark. I have a 2012 K13 with engine stop/start function, does anyone know how to disable or to remember your setting. I would like not to have to push the button every time. Thank you IMG_8209.heic
  24. This is my first Nissan experience; I have only driven 400 miles in the last 3 weeks. Not even fully run in yet, however so far so good and have been pleasantly surprised
  25. Hello, I wonder if anyone has had the same issue as me. The steering emits a squeak when it there is moisture in the air, so during the warm months since I got the car in June, no noise at all. You can imagine what it has been like recently since it has been raining.... The forecourt I bought the car from has there own garage and they apparently have greased the steering joint, both side since they replaced the gearbox (under warranty) I am going back to them with this continuing issue, but I wanted to see if anyone on here has had the same issue and what it was? Thanks.
  26. Hi I’m after some advice regarding have a wet drivers seat ,I’ve unclogged sunroof drainage hose and that’s ok,.Im not sure why it’s wet,the carpet is dry,any clues on what to do next. thank you
  27. Hi Simon...welcome to the Club You certainly have a good collection of Nissans Good to have you onboard
  28. In the UK there is a windscreen company called Autoglass and they have all the equipment and necessary knowledge to set up the ADAS If there is somewhere similar in Sweden that you could take the car to for a check and if necessary get them to set it up correctly
  29. Just out of the blue. No prior incident or anything out of the ordinary.
  30. Thanks for the tip, I will check them out. Cheers.
  31. I have used a company before that specialise in aftermarket audio replacement https://www.iceboxauto.com/nissan-murano-2015-18-gps-navi-android-auto-11-carplay-oem-style-radio-ni072 Not sure if the one listed is the same style as it states it for a later model?
  32. First thing I would have suggested is fitting a new good quality battery. Also, not entirely sure if maybe the stored battery voltage needs resetting with a scan tool
