Elorac90 joined the community
Geoffbiddukph joined the community
Gra joined the community
jdog72 joined the community
SerenaNewBee joined the community
grandpa1466 joined the community
David B joined the community
sundeep joined the community
Trieze joined the community
chris gould joined the community
The truck has been sold.
