Drchops joined the community
MacMerc joined the community
ff2nd joined the community
vassevda started following Engine number pulsar dci diesel
vassevda joined the community
Foxtrot0mega started following 2013 nissan micra internal fan blower
Hi all! ππ» I'm currently having a massive issues with my micra k13 2013 acenta. The internal heater blower only lets through a teeny tiny amount of air. So far we have tried: Checking fuses and relays all are working - still the same Replaced pollen filter - still the same Replacing resistor with 2 other ones - still the same Replacing the heater blower fan by taking the whole front dash out (not fun!) - still the same When standing outside the car and the fans are switched to an on position you can hear the noise like the fans are on inside the cab but still a teeny tiny amount of air is coming through. What else could it be as we are at our wits end. Any suggestions are welcome please π π Thank you for taking the time to read this, it is very much appreciated
Foxtrot0mega joined the community
Louise00 started following Wheel wanted for Micra Spec Ed 25 (2008)
Iβm looking to buy a replacement wheel for my Micra Special Edition 25. As you can see in the photo itβs an 8 spoke alloy and 175/60R15. Could anyone advise where to get one from please? Thanks in advance!
Louise00 joined the community
Deet27 joined the community
COL2ADAM1 joined the community
Trevor started following Hi New to Nissan Owners Club , Pixo clutch / gear selection , Jimi! and 2 others
Hi - welcome to the Club Fine looking Juke, not so sure I would manage to keep that paintwork clean all the time π Good to have you onboard!
Hi Trevor - welcome to the club good to have you onboard and enjoy your Qashqai π
Hi, Iβve replaced the horn in my 2005 Urbis and managed to accidentally break the wire next to it that goes into the radiator. Can anyone kindly confirm what it is and what it does so I can get a new part?
