  2. usually when charging, whether on a charger or from an alternator it will usually sit in the 13v mark. Interesting to that the interior light causes that surge, battery maybe weak for some reason, although 4 years is not that old. But stuff happens. might be worth investing in a scan tool when the car comes out of warranty. As dealers charge so much money for such little work
  3. Thanks for your support, Steve. I tried to replicate your instructions but I could not get the response on my Leaf no matter what buttons I pressed! One thing I did notice was the 12v battery (it's always the 12v battery!) was only reading 12v and any load such as interior light dropped it to less than 12. I have now put the vehicle on charge and notice that this also charges the 12v battery, now reading over 13v. Hoping this might be the answer. But if not the car is in warranty so will take it back to the dealer for them to fix.
  4. please let us know the results and what it was.. may help other leaf owners Cheers
  5. good morning Usually you would need to have a scan tool to scan the faults. There maybe a way to do this manually, but I dont have a leaf to test this on. Sit in the driver seat (car OFF). Press and hold the trip reset button on the dash. While holding it, press the Power button twice (don’t press the brake). Keep holding until the dash flashes and displays “DIAG” or icons. Release the button. Press the trip button again to scroll through system checks. If you only see “---” or no data, you’ll need a scan tool for detailed fault codes. Give that a go. But i am no expert so if you get no joy then have this inspected by a dealer.
  6. My 2021 Leaf Acenta is showing System fault on the screen. Pressing OK removes the message but there is an orange exclamation mark at top of screen. Any ideas as to what would be the fault?
  7. UK-SRi replied to VG1's topic in Infiniti
  8. Last week
  9. UK-SRi joined the community
  10. timeo4 joined the community
  11. maryclairec3 joined the community
  12. toyac96083 joined the community
  13. I have a 2011 Nissan Pathfinder is there any lower kids for? It
  14. Latinbarber813 started following Lowering kit
  15. Latinbarber813 joined the community
  16. Mstead joined the community
  17. Hi everybody! Nissan Qashqai 2017 1,6 diesel, cvt. About 86000 miles So the car starts and runs fine, but I noticed a slight knocking upon coldstart. Almost as if the engine is having trouble building oil pressure. For about 4-5 seconds. And I have crankcase pressure opening the oil fillercap + some smoke. So a Pcv problem I thought. Changed the pcv and the knocking upon starting might have been slightly less. But still crankcase pressure. If I disconnect the hose on the pcv and blow in it, there are not resistance. And I can’t find any defects on other hoses. I notice a sound from the airfilter box, as if the engine is sucking air from a leak in the box. Dismantled everything but can’t find any leak. Some oil in the hoses and around the filler cap, but nothing alarming. Haven’t done a compression test as it’s not a high mileage car. Full service book. Drives 40 + 40 miles everyday. Can’t upload film as it’s to big.. Anyone who has experienced the same problem.
  18. Try this company https://www.petrolcaps.co.uk/
  19. Sounds like they have arrived a diagnostic conclusion which seems quite reasonable. Not sure why it cuts out though, but sometimes this can occur when the engine revs 'stumble' Please let us know how it all goes
  20. If it is coming from the interior (e.g. back of the steering wheel) then it could be the SRS rotary coupler as they can suffer from moisture and dirt ingress over time
  21. Tomas joined the community
  22. doniblade joined the community
  23. I used Lens on my old Alphard years ago.. worked a treat. once settings set up then let it be.
  24. I would use google lens and translate functions to define which controls do what
  25. Hi....welcome to the Club Please let us know how you get on with it all Good to have you onboard
  26. Hi .... welcome to the Club Nice collection of cars - good to have you onboard
  27. Earlier
  28. Only done 10 miles but loving it already. We did have a Kadjar as a company car for 2 years so I had an idea of what it would be like.
  29. I bought an Elgrand converted to a campervan. Very nice job, but all the controls have Japanese text and the handbook I got doesn't help much. Does anyone know anything about the Elgrand? Thanks David
  30. Hi I have a 2017 Nissan Qashqai J11 St auto petrol model. The orange malfunction indicator light has been on for a while now. I have had the vehicle several times to an auto electrician who has reset it and the code was P0303 with the message that the 3rd cylinder is fisfiring. I have also had it to the local Nissan dealer who again reset it with the same error code showing up. It has had a new coil ignition pack put in as well as a standard service with new spark plugs. It has recently started to shudder a bit when driving and the motor has cut out and stopped when I am stationery. It restarts again when I turn it over. I have taken it to another mechanic and they have swapped the 3rd and 4th injectors to see it that would make a difference. The malfunction light has stayed off, however they got me to take the car on a drive at a speed of 100klms to see what happened. In doing this, the light came back on for a few seconds and went off again but the motor cut out again when I stopped at an intersection. They have rescanned it again and it is now showing that the 4th cylinder is fisfiring which indicates that the injector/s need replacing. Just wondering if anyone else has had this situation before and what the outcome was. Thank you. Debbie. Queensland
  31. Not on late models as it an EU requirement as I understand it. Mine is set up with a shortcut to turn audio warning off by pressing control switch and Okay.
  32. Just purchased another Japanese branded car (3rd one) a 2025 Qashqai e-Power with 5200 miles on the clock (ex demo from main dealer). First one built here in the UK - the Mazda 6 and Honda Accord both shipped to the UK. The later two proved ultra reliable so we'll see how built in Britain goes - well I hope! Any tips on economical driving techniques for e-Power would be appreciate. TIA
  33. LAL posted a topic in Nissan Pathfinder Forum
  34. I’m a former owner of three 280Z cars. Although I’ve also owned early Porsche 356a, 356c and 911 cars, the Z cars rank highest in my heart. Now the owner of. 2012 Nissan Rogue and it has all of the issues that it is famous for - but I refuse to give up. So, I will be questioning the forum regarding my CVT repair attempts, codes and results. Here goes!!
  35. welcome to the club !!
  36. Enjoy the Qashqai!! im sure it will be better than the note!
  37. Picking up my new to me Qashqai on Saturday. It's a 2017 1.5 dci Tekna. Previous car was a Nissan Note that, for various reasons, I was never happy with ! 🤷
