  2. You may be able to get the spheres re-gassed.....you could do on the Citroen and Hydrolastic spheres many years ago - look up Sphere repairs or regas
  3. Hi Stuart....welcome to the club I would say just have the vehicle checked over at a garage and if it is in need of a service to then have this carried out before venturing abroad. Also check your tyres for wear or damage and make sure all your lights are in working order. You may need to get vehicle passes such as Vignettes but otherwise, convert your headlamps so that the beam is deflected to the other side (can get a kit from Halfords for that). Good luck and enjoy your trip
  4. Sorry that no one responded to your post. One of the reasons on the old Micra 4 cylinder engine for poor idle was carbon build up in the throttle body. When it is cleaned out and refitted, you would then have to perform a reset on it through a diagnostic scan tool which should sort it
  5. Yesterday
  6. When I had this i thought it was a phone or car setting. Can't really remember but I did get it to stop by altering which ever setting it was.
  7. Last week
  8. Well after the influx of msg on here 😒 I bit the bullet and bought 3 new coil packs. Turns out the readings I gave above are correct and I didn’t need the 150 quids worth of coil packs.
  9. The truck has been sold.
  10. Kind of resolved this now a bit. It still has a slightly rough idle in my opinion but it is a 3 cylinder so could just be the nature of the car?? any way I metered out the coil packs all seem to be the same and as I don’t know what they are supposed to be I’m going with they are ok? I also unplugged them one by one and the engine started to misfire as expected. I removed the throttle Body and gave it a good clean. It wasn’t too bad but there was a little bit of oil in there. I also unplugged the fuel solenoid purge valve and let it run for a second or so and plugged it back in. I also found that both battery terminals were very loose! So they got tightened up as well. Since doing this it seems to idle better. The only time the revs seem to hunt is when the ac is on now and the highest it goes is up to about a 1000 when the clutch kicks in which I’d kind of expect as there is extra load on the engine.
  11. hi all does anybody know how to check fault codes on a 2017 nissan micra K13 x 1.2 litre petrol i have 2 scanners ( cheapies ) which reads my kia fine but this nissan cant connect to ECU
  12. Hi does any one know what the resistance values across the coil pack should be? my 2017 micra is running a bit rough and hunts on idle but I can’t see or hear any air leaks. iv serviced the car including new iridium plugs and just put a full tank of premium fuel with red ex fuel cleaner init. I’m kinda running out of options on what this could be. Next step is to clean the throttle body but I’m thinking possible coil pack issue as well. im getting 79.4kohm between pins 1&3 and 0.47Kohm between pins 1&2 and 79.45kohm between pins 2&3 and that’s on all 3 coil packs as well ( slight differences between them) there is no EML light on the dash either and my scanners are not picking any fault codes up
  13. Hey guys, not sure if this is the right place to post "for sale". Sorry about that. I'm selling my 1 owner Pathfinder SE. 70,125 miles. Engine and trans in perfect running condition. Does need a SAS and flex plate. I have all service/oil change receipts. Asking $4500 neg.
  14. Hi. I have a qashqai j11 2016 n connecta. A couple of days ago I turned on the radio and no sound. I have tried a reset but no joy. I rang nissan dealer they wanted £150 to diagnose. And if I need a new headunit it's £3000 thats three thousand not a typo lol. Has any got any ideas. A friend suggested a memory fuse gone in the unit but I can't find one listed. Any ideas welcome.
  15. Earlier
  16. My son is the proud new owner of a 2006 X-Trail T-30 as his first vehicle. Generally, it's in great condition, but it does need some bodywork to deal with rust. We are seeking recommendations on where to look online for replacement parts, ideally in Canada but open to internal suggestions. Specifically: Left Quarter Extension Left Quarter Reinforcement Thank you in advance for any advice or experiences.
  17. Hi Iv just picked up a 2017 micra with the 0.9ltr engine in from Copart. It’s got a slightly rough idle, Iv just replaced the plugs and oil and filters on the car as I don’t know the history. It’s done 54k miles the evap system seem to be working ok. I don’t have a vacume pump to check properly but it’s not getting blow by out the dipstick or the filler cap. im a bit to remove the throttle body and clean it but after this I’m kinda stumped. Unfortunately my code reader is showing nothing on the system and there is no lights on the dash. Short of replacing all the coil packs I’m stuck. Any ideas?? on start up it also has a high idle as well seems to sit around 1500 and then drops off to around 800. I’d expect this on a cold morning for the cold start but it’s not been cold.
  18. Hi all, Stuart hers from Scotland and I have just purchased a 2013 Qashqai tekna 1.5 diesel with 71k on clock. I will be using this car to drive to Spain and wondering if there is anything I need to address before I start the journey. Many thanks, Stuart.
  19. Firstly thanks to admin et all for the inclusion of your forum ...... Had a Navara some years back ... dreaded chassis issue and managed a buy back from Nissan Nordics as I live in Sweden. .. Just bought a 2018 NV300 and am trying to remove the drivers arm rest to fit an aftermarket seat cover... centre cap removed and a plastic long squared centre piece revealed.... any clue on how to remove please?... Have put grips on it and tried to ease it free and even put a shifter on it to hopefully slacken it off .... but to to avail ....any one had any experience with this that they could pass on valuable info? Thank you in advance Dox
  20. hi Because I am very happy owner of Nissan Cima 2010 VIP model I imported another Nissan ..now classic 1994(late model from September) very rare with Automatic ACTSUS system. and here is a little clip with my Nissan. NEAR all works as it's looks .I need help with 2 things. Im pretty sure all 4 gas spheres( similar to Citroen with hydroactive suspension )dont have enough Nitrogen pressure and Im looking to buy 4 speheres after regeneration or refuel mine. And second problem Im trying to find Consult in my car and REALLy cant..I spoke 2 days with 2 different AI and they are giving me excluding answers. I found some of this car models DONT HAVE it.. AT ALL- I dont have any problem - nothing flash but I want to have possibility to diagnose my car if anything happend.Would be nice if some one of You have more experience with this BEAUTY and can help me. Here is How its look: here is small clip with my BEAUTY NISSAN
  21. You could try IceBox Autos who make units to specifically fit your car
  22. Our 2018 Micra K14 does not have the Carplay unit fitted which is annoying my wife who is the main driver. Does anyone please know if there is a aftermarket Carplay unit that actually works that we can have fitted to this vehicle?
  23. I would suspect it is the brake pads moving backwards and forwards - usually happens if the pads fitting kit is missing and allows the pads to move in the carrier. If it was the driveshaft joint then it would be constantly be clicking on acceleration and deceleration
  24. Did you resolve the issue? I was thinking it may be the Dual Mass Flywheel (if manual transmission) starting to break up Usually noticeable when switching the engine on/off when it will start to rattle
  25. a quick search with Google Lens reveals some results Just right click over the image above and select search with Google Lens and it brings up results of products that roughly match the clips you're looking for
  26. So, here's the saga. Offside Drum collapsed inside, my fault- long story. Anyway, new drums, studs, bearings, shoes, spring kit purchased, but could I find an ABS ring for the pixo anywhere? Nope! Eventually, Vertu Nissan offered me 2 rings for £201!!! Bought 2 used drums, cleaned/painted and fitted. ABS light turned off 👍 Moral of the story: Parts like this are becoming very difficult to get. Also, does anyone have any ABS rings? I have 2 brand new drums, with new bearings pressed in and ready to. They'll need the fings fitted, obviously. You can have them both for £50 plus whatever the p&p will be Tony
      • 1
      • Like
  27. occasionally i get a noise from the o/s/r of my car and a red warning light flashes briefly on the dash(i think it is a master warning light) .After a second the light and noise disappear and everything is ok. Performance and braking are not affected . The noise sounds a bit like ABS Working . Had rear pads replaced and a recent Mot all ok. Noise returned briefly a couple of days ago again just for a second .Usually happens on or near a corner .Any ideas???
  28. Hi, my mum has a 2005 Micra, she doesn’t want to sell it, ever. It has c40k mileage and drives like a dream! But, the tailgate switch has failed and I’m struggling to get a replacement - it’s the intelligent key version - part number 25380AX10B. Any ideas please?? There loads of the 25380AX60B but these aren’t compatible with the intelligent key. Thanks in anticipation!
