  2. Hi everyone, I’m having a really annoying problem with my 2019 Nissan Qashqai J11 (petrol). All the safety and radar-based systems have started to act up – the front collision warning, side collision, and blind spot warning all trigger in sequence. The error messages appear, then reset, and come back roughly every 10 seconds, no matter what I do. In the beginning, it only happened once after the car had been parked for about a day, but now it happens constantly whenever the car is running. The ADAS control unit has already been replaced by an official Nissan workshop, but the issue remains exactly the same. They’ve spent two full days diagnosing it without finding a clear fault. No specific sensor fault codes were stored either. I’ve checked the camera wiring behind the rear-view mirror, since I know I’ve previously moved that cable slightly because it was creaking. I’ve opened the cover and inspected the connector — everything looked clean and fine, but I haven’t done more than that. The sequence of warnings always starts with the front collision alert, then the side and blind spot systems follow a few seconds later. The battery has been replaced by Nissan already so that is ruled out. At this point, I’m stuck. Has anyone seen similar behaviour on the J11? https://share.icloud.com/photos/04aB5DH7H_CRWKt8RlSVHB7lQ
  4. Last week
  5. Hi As the title suggests, I'm looking to replace the CD/Nav unit in my 2009 Murano. I'm in New Zealand, and this vehicle (which I purchased a year ago & love) is a Japanese import. The language on the entertainment unit is in Japanese (although portions of the dash face are in English, which I find strange in itself!), and I want to change the screen display language to English. Don't want to use an after market replacement as the AC controls run through the existing one, and I would be flying blind if this wasn't coming up on the screen to show me what's happening. A local parts company has a factory replacement unit, which they say is in English, but in the discussion the parts company rep mentioned about the control unit for language being located elsewhere (as in outside of the CD/Nav unit) and swapping out the unit itself may not fix this. Does anyone have any info if this is the case, or general info on swapping the CD/Nav unit out? Thanks.
  6. I have a 2014 Nissan X-Trail automatic 1.6 diesel. The problem is that I’m getting a “system fault” warning, and at the same time, both the start-stop system and the cruise control are deactivated. I should note that the battery is new.
  7. Hi ..... welcome to the Club It's a perfect car for local use more so than motorway but it should be mostly reliable and also economical Enjoy the forums
  8. It does sounds like a loose or worn belt but equally I have found so many of the new belts nowadays are more silicon based than rubber based compound. They slip for a past time until they get warm. Try to stick to genuine manufacture belt (avoid anything made in china) Check also the tensioner is okay and if worn then replace this at the same time
  9. Earlier
  10. Hello, my partner drives a Micra DIGs. It has approximately 70k miles. Upon starting it there is a distinct belt or tensioner/pulley squeal.. it comes from the front end of the engine. It does go away fairly fast as soon as the revs go up. I know I should change the belt and see but I have two questions: 1) does anyone know the exact part code or any to the right type of belt? 2) is it doable for someone with basic knowledge/tools and space? I have changed drive belts/tensioners/plugs coils/filters oil etc in a c7 corvette and in a zl1 camaro on my driveway but those (being yanks) can be very easy cars to work on and didn’t require any big parts to come out. (Only fuse boxes/filters etc). thanks in advance guys
  11. I bought this: Tuqiang Car Seat Covers For Nissan X- Trail 2014-20 5 Seat Full Set PU Leather but the purchase fell through so it is now up for sale. It is not used. It is listed on ebay https://www.ebay.co.uk/itm/297629455187
  12. I just tried taking down my spare tire to check the air pressure. Needless to say, I don't think it had ever been out. Due to the cold climate (Salted winter roads, Northern Canada), the bolt was very rusty and try as I might, no lube was enough and I snapped the bolt in the "hook" assembly that holds the spare tire carrier up under the car. Does anyone have a usable bolt and hook assembly that they'd be willing to sell?
  13. I picked up a 2015 Micra S for a commuter car. I love it and look forward to tinkering with it.
  14. there are some posts on google search relating to the PO409 code I would first start by running some cleaning solution through the fuel and give the engine a very long high revs run to burn off any excess carbon that has collected in the EGR or Intake Manifold
  15. mostly timing chains are reliable if the correct servicing and maintenance is carried out when its specified and using quality oils and filters Please let us know how it goes !
  16. possibly air mass meter is causing the jerking - try removing, cleaning and replacing Another possible cause could be the throttle pedal sensor needs replacing? Have you turned off the air conditioning as this will run a fan on start up
  17. thanks for updating us and please let us know how it proceeds
  18. The Qashqais have only got the fuel flap protecting access to the fuel inlet. Is it possible to fit a locking fuel cap inside the body flap? If so anyone know of where to get one. please.
  19. Nissan are looking into my new car that was not giving the advertised range of 759 miles on delivery as they said it should (only giving 660 a 100 mile discrepancy. Car delivered with full fuel tank and only delivery mileage of 10 miles). second tank fill still only 660 range. Awaiting their investigation!
  20. Hi all, Got a 2014 d40, eml came on for egr so has been replaced. However eml came on again after clearing faults with PO409? What could be the fault? Wiring or something more sinister
  21. Bonjour, Je rencontre un problème avec mon Nissan X-Trail 1.6 de 2014. Depuis un certain temps, la voiture présente des à-coups et des hésitations notables et ne semble fonctionner correctement qu'en 7e vitesse. De plus, quelle que soit la durée du trajet (même les trajets très courts d'environ 2 minutes), le ventilateur du radiateur s'enclenche immédiatement et continue parfois à fonctionner sans s'arrêter, ce qui finit par vider la batterie. Quelqu'un a-t-il rencontré des problèmes similaires ou pourrait-il suggérer des causes possibles (moteur, transmission, système de refroidissement, électricité) ? Merci d'avance pour toute contribution.
  22. Hallo den habe ich erfolgreich eingebaut: L7808 Spannungsregler 8V DC gruss Michael
  23. Ok. I did buy some oil recently im just waiting on the filter and sump bolt to arrive from euro car parts. Ill try not to drive it as much until it arrives. thanks Also are these known issues with these cars? I dont really know much about them because I wasn't so interested in them at first.
  24. Manufacturers were all found guilty of doctoring the figures by any means necessary - so they really are just guidelines. Your driving style, routes, terrain will all play a part in the overall fuel consumption....even air conditioning and having a roof box will play a part in the outcome
  25. I would check the coolant pressure cap as my first point of call - replace if necessary as its quite cheap and take 30 seconds to do (only release the cap when the engine has cooled down)
  26. I would advise changing the engine oil and filter as soon as possible. Having looked up your cars registration on Eurocarparts, it is listed as having a timing chain Try to locate a quality oil filter and get the best oil you can for the money - Castrol, etc
  27. 20250925_103247.mp4 Hello! I have recently bought a k12 micra for my first car. There are a few issues with it obviously being a 16 year old car but one sticks out more than the others. When I specifically start the car from cold there is a rattling noise coming from the drivers side of the engine. I was going to carry out an oil service myself because I dont know when it was last done and the oil doesn't look great. I mean that its mostly black but there is still a bit of a goldy brown colour. I understand cars make noises but its just been really playing on my mind because i could not afford to do a timing chain or a new engine if something were to go wrong. The reg number is Bv58 dkd if you need engine sizes/ codes etc Thanks! Johnny (I would have sent a longer video however there is a lomit of roughly 6mb)
  28. Just bought the new 2025 e-power Qashqai with an advertised range of 759 miles. It was given a full tank of petrol by the dealership with delivery mileage of 10 miles and the range was only 660. (The salesperson said he was surprised when he filled up and noticed the range was only 660). It was explained that the car was to learn the drivers habits and range would be noted accordingly. Surely it should have given, as new - undriven, the advertised range of 759 and then yes as it adjusted to driving habits the range would alter. I changed from a 2024 e-power Qashqai and with our driving habits managed to achieve, or thereabouts, this models range of 550 miles which it was started with. Both of the models being the N-Connecta.
  29. Guys can you help love my pathy , got an issue. Thing over heats had head gasket done but points to possible cracked head is this fixable , or is it something else I’ve got a intercooler fitted ??? also back end classic has hole in it where is the best place or reliable mechanic who can work on this in the northants area help me
