  2. AndyD joined the community
  4. Leo D joined the community
  5. Dai2025 joined the community
  6. Razers joined the community
  7. NYXTERIDAS joined the community
  8. Peter by the lake joined the community
  9. BIG-COL joined the community
  10. Rhino posted a topic in Nissan Pathfinder Forum
  11. used to see this with black electrical tape. does the job.
  12. Hi Trev . It's " Glow plug fault on circuit A" on my reader .
  13. alishatest joined the community
  14. What fault codes are you getting from the scanner readout?
  15. You could try covering the beam pattern in the correct portion of the headlamp with cardboard (and bluetack) before fitting the stickers. This way you can see if the beam pattern is no longer pointing to the kerb (UK spec lights) and it doesn't necessarily have to deflect it to the other side but just not dazzling the oncoming traffic. This means it may reduce your vision on the kerbside (European spec lights) but at least you are legal.
  16. Anousha joined the community
  17. V8Pathfinder joined the community
  18. YES! Night ferry ....
  19. Hello everyone , I'm Steve, a new member & would appreciate any help with my 1.6 dci 2012 qashqai. my obd reader indicated a faulty circuit A , I replaced all glow plugs , but problem persists , long cranking especially in cold weather , to start the car . I gather the relay or fuse may be responsible , but unsure of there location & accessibility . Any help appreciated ! Thanks
  20. this is for a campervan but has some good points
  21. will you be driving at night?
  22. Thanks for replying! Um, yes, I got square eyes looking on Youtube and found nothing. Hence my message on here. 🙅‍♀️
  23. Hi Rose Are you likely to be driving at night? If yes then they should go on the nearside (passenger side) but yes your right, its not easy. I drive without them as I have flat LED but if you want to be legal then stick them on. Have you tried Youtube?
  24. Hi folks! I'm driving to France so need to put on some beam deflectors on my Qashqai 2021. I've bought Eurolites, and having read the instructions I understand that I need to apply them using picture 146 but to be honest, I really don't understand where to stick them! (Also they're not the same position on both lights 🙄) . I've been looking, but can't find, any photos of beam deflectors on Qashqais so I can copy. Can anyone help?? Am I the only one who finds this difficult? Any advice gratefully received. TY
  25. I need rear brake adjusters for my 85 Stanza hatchback, its a T-11
  26. Earlier
  27. Hi
    Welcome to the club @Rhino
  28. Hi
  29. Trevor started following OBD for Leaf , Hi , Micra Business 2022 and 1 other
  30. Hi
  31. Hi Trevor, thanks for your suggestion. I'm not all that savvy with this internet thing. I'm with Orange in France. I presume when the Micra is asking for my password they mean the long list of letter and numbers that came with my love of. I have had to use that to get the internet on my tablet and laptop . Is there any other password?
  32. Hi...welcome to the Club sounds simplistic - but can't you change your internet password to a shorter one so that the characters fit?
  33. What is the actual issue with the car? Also, is it engine speed or vehicle speed sensor you are looking at?
  34. I've never used a forum so bare with me please. I have a 2006 6cyl Pathfinder 4×4. I need to find out exactly where the input shaft speed sensor is located!! Took the driver wheel off and can't even see where it goes!! Help please . I know on outside of tranny! HELP
  35. ☹️internet connection Recently bought a 2022 Micra Business K14. For some reason it won't accept the last digit of my Internet password so I cannot get Nissan updates. Why
  36. I know... so nothing. But, Thanks.
  37. I use iCarSoft scanner so not sure about the Topdon but most scan tools are of the same standard and will read and delete fault codes. Beyond that, scanners such as the iCarSoft can also code injectors, reset base values and quite a bit more
  38. The only thing I can think of is when you lock/unlock and hold the button down for a period of time then the windows will lower or raise? Otherwise, not sure what could be causing it to drop the windows
