  2. It has a camera in the rear, so does it mean it will also have sensors at each corner
  3. Hi @Sam Deano64 - Welcome to the club. Any aftermarket dampers such as Koni will improve the handling over the standard equipment. Worth running a search on eBay for reputable brands and relatively easy to fit and you will see an immediate improvement
  4. Hi @Isaac - welcome to the club I would put money on the hybrid system kicking in and out which can cause a slight 'stumble' when it cycles so wouldn't worry about it unless it gets any worse.
  5. I know there are boot organisers on the market that suit most cars but not sure which one would be best to even if they custom make them to suit the vehicle. Worth doing a search on eBay for what is available for the Qashqai
  6. It looks like the rear parking sensors are playing up - maybe covered in mud or something else obstructing them or one of them is faulty. If you put the car in reverse with the ignition on and engine off then go to the back of the car and each sensor should make a very quiet clicking sound if they are working...if not then replace the faulty sensor
  7. Hi @Bebop Cowboy ...welcome to the Club Had a few X-Trails myself and they are superb to drive - never really tried them off-road though. Good to have you onboard!
  8. Could anyone tell me what this system fault is indicating
  9. pandora joined the community
  10. JeffMc joined the community
  11. Last week
  12. Griffmt10 joined the community
  13. endy joined the community
  14. I own a 2016 Nissan Qashqai and am wondering if it’s possible to add more organised boot storage for tools and travel gear. Has anyone modified the boot layout on this model year, and what solutions worked best?
  15. dradem joined the community
  16. Hi there I just got my first car... and it is a beast! 2 litre diesel X-Trail Got loads of questions that I'm hoping will have already been answered in the forums. Looking forward to picking up hints and tips :)
  17. Bebop Cowboy joined the community
  18. Hi guys for those with a 2021 Juke Gen II, has anyone upgraded the suspension to improve comfort or reduce body roll? Curious about real world improvements? sam
  19. Thanks for the add My 2024 Qashqai e‑Power sometimes hesitates when accelerating gently between 20–40mph. Has anyone diagnosed the cause, software behaviour, a sensor problem??, or hybrid energy management quirks? Cheers Guys
  20. Isaac joined the community
  21. Sam Deano64 joined the community
  22. Skipper82 joined the community
  23. Dodge Jamie86 joined the community
  24. I would be measuring the glow plugs (old and then compare to new) at least so you could identify which cylinder(s) is at fault.
  25. Rhino posted a topic in Nissan Pathfinder Forum
  26. used to see this with black electrical tape. does the job.
  27. Hi Trev . It's " Glow plug fault on circuit A" on my reader .
  28. What fault codes are you getting from the scanner readout?
  29. You could try covering the beam pattern in the correct portion of the headlamp with cardboard (and bluetack) before fitting the stickers. This way you can see if the beam pattern is no longer pointing to the kerb (UK spec lights) and it doesn't necessarily have to deflect it to the other side but just not dazzling the oncoming traffic. This means it may reduce your vision on the kerbside (European spec lights) but at least you are legal.
  30. Earlier
  31. YES! Night ferry ....
  32. Hello everyone , I'm Steve, a new member & would appreciate any help with my 1.6 dci 2012 qashqai. my obd reader indicated a faulty circuit A , I replaced all glow plugs , but problem persists , long cranking especially in cold weather , to start the car . I gather the relay or fuse may be responsible , but unsure of there location & accessibility . Any help appreciated ! Thanks
  33. this is for a campervan but has some good points
  34. will you be driving at night?
  35. Thanks for replying! Um, yes, I got square eyes looking on Youtube and found nothing. Hence my message on here. 🙅‍♀️
  36. Hi Rose Are you likely to be driving at night? If yes then they should go on the nearside (passenger side) but yes your right, its not easy. I drive without them as I have flat LED but if you want to be legal then stick them on. Have you tried Youtube?
  37. Hi folks! I'm driving to France so need to put on some beam deflectors on my Qashqai 2021. I've bought Eurolites, and having read the instructions I understand that I need to apply them using picture 146 but to be honest, I really don't understand where to stick them! (Also they're not the same position on both lights 🙄) . I've been looking, but can't find, any photos of beam deflectors on Qashqais so I can copy. Can anyone help?? Am I the only one who finds this difficult? Any advice gratefully received. TY
