  1. Last week
  2. So, a little update on ours! We've managed to get a warranty replacement agreed via Ancaster and Nissan UK. We had to prove service history and it's going to take 6-8 weeks because there's a part out of stock (they've already had it 6 weeks). It took some arguing but definitely worth pursuing, especially if you've maintained your vehicle.
  3. Thanks. No instruction hadn't changed anything. Just did reset when it stopped working.
  4. Have any of the settings changed (e.g. bluetooth to your phone, etc)? I would try pressing a few buttons to find mute, volume, etc If it powers up then it won't be a fuse thats blown
  5. Sounds like you have sorted it then - well done! You have done all the checks in the correct way and come to the right conclusion Only other thing maybe to recode the throttle body which was a thing on the slightly older Micra but may still apply A good scan tool should have this function on it
  6. You could try using different protocol settings on the scanners (if available) to read the codes
  7. You may be able to get the spheres re-gassed.....you could do on the Citroen and Hydrolastic spheres many years ago - look up Sphere repairs or regas
  8. Hi Stuart....welcome to the club I would say just have the vehicle checked over at a garage and if it is in need of a service to then have this carried out before venturing abroad. Also check your tyres for wear or damage and make sure all your lights are in working order. You may need to get vehicle passes such as Vignettes but otherwise, convert your headlamps so that the beam is deflected to the other side (can get a kit from Halfords for that). Good luck and enjoy your trip
  9. Sorry that no one responded to your post. One of the reasons on the old Micra 4 cylinder engine for poor idle was carbon build up in the throttle body. When it is cleaned out and refitted, you would then have to perform a reset on it through a diagnostic scan tool which should sort it
  10. When I had this i thought it was a phone or car setting. Can't really remember but I did get it to stop by altering which ever setting it was.
  11. Earlier
  12. Well after the influx of msg on here 😒 I bit the bullet and bought 3 new coil packs. Turns out the readings I gave above are correct and I didn’t need the 150 quids worth of coil packs.
  13. The truck has been sold.
  14. Kind of resolved this now a bit. It still has a slightly rough idle in my opinion but it is a 3 cylinder so could just be the nature of the car?? any way I metered out the coil packs all seem to be the same and as I don’t know what they are supposed to be I’m going with they are ok? I also unplugged them one by one and the engine started to misfire as expected. I removed the throttle Body and gave it a good clean. It wasn’t too bad but there was a little bit of oil in there. I also unplugged the fuel solenoid purge valve and let it run for a second or so and plugged it back in. I also found that both battery terminals were very loose! So they got tightened up as well. Since doing this it seems to idle better. The only time the revs seem to hunt is when the ac is on now and the highest it goes is up to about a 1000 when the clutch kicks in which I’d kind of expect as there is extra load on the engine.
  15. hi all does anybody know how to check fault codes on a 2017 nissan micra K13 x 1.2 litre petrol i have 2 scanners ( cheapies ) which reads my kia fine but this nissan cant connect to ECU
  16. Hi does any one know what the resistance values across the coil pack should be? my 2017 micra is running a bit rough and hunts on idle but I can’t see or hear any air leaks. iv serviced the car including new iridium plugs and just put a full tank of premium fuel with red ex fuel cleaner init. I’m kinda running out of options on what this could be. Next step is to clean the throttle body but I’m thinking possible coil pack issue as well. im getting 79.4kohm between pins 1&3 and 0.47Kohm between pins 1&2 and 79.45kohm between pins 2&3 and that’s on all 3 coil packs as well ( slight differences between them) there is no EML light on the dash either and my scanners are not picking any fault codes up
  17. Hey guys, not sure if this is the right place to post "for sale". Sorry about that. I'm selling my 1 owner Pathfinder SE. 70,125 miles. Engine and trans in perfect running condition. Does need a SAS and flex plate. I have all service/oil change receipts. Asking $4500 neg.
  18. Hi. I have a qashqai j11 2016 n connecta. A couple of days ago I turned on the radio and no sound. I have tried a reset but no joy. I rang nissan dealer they wanted £150 to diagnose. And if I need a new headunit it's £3000 thats three thousand not a typo lol. Has any got any ideas. A friend suggested a memory fuse gone in the unit but I can't find one listed. Any ideas welcome.
  19. My son is the proud new owner of a 2006 X-Trail T-30 as his first vehicle. Generally, it's in great condition, but it does need some bodywork to deal with rust. We are seeking recommendations on where to look online for replacement parts, ideally in Canada but open to internal suggestions. Specifically: Left Quarter Extension Left Quarter Reinforcement Thank you in advance for any advice or experiences.
  20. Hi Iv just picked up a 2017 micra with the 0.9ltr engine in from Copart. It’s got a slightly rough idle, Iv just replaced the plugs and oil and filters on the car as I don’t know the history. It’s done 54k miles the evap system seem to be working ok. I don’t have a vacume pump to check properly but it’s not getting blow by out the dipstick or the filler cap. im a bit to remove the throttle body and clean it but after this I’m kinda stumped. Unfortunately my code reader is showing nothing on the system and there is no lights on the dash. Short of replacing all the coil packs I’m stuck. Any ideas?? on start up it also has a high idle as well seems to sit around 1500 and then drops off to around 800. I’d expect this on a cold morning for the cold start but it’s not been cold.
  21. Hi all, Stuart hers from Scotland and I have just purchased a 2013 Qashqai tekna 1.5 diesel with 71k on clock. I will be using this car to drive to Spain and wondering if there is anything I need to address before I start the journey. Many thanks, Stuart.
  22. Firstly thanks to admin et all for the inclusion of your forum ...... Had a Navara some years back ... dreaded chassis issue and managed a buy back from Nissan Nordics as I live in Sweden. .. Just bought a 2018 NV300 and am trying to remove the drivers arm rest to fit an aftermarket seat cover... centre cap removed and a plastic long squared centre piece revealed.... any clue on how to remove please?... Have put grips on it and tried to ease it free and even put a shifter on it to hopefully slacken it off .... but to to avail ....any one had any experience with this that they could pass on valuable info? Thank you in advance Dox
  23. hi Because I am very happy owner of Nissan Cima 2010 VIP model I imported another Nissan ..now classic 1994(late model from September) very rare with Automatic ACTSUS system. and here is a little clip with my Nissan. NEAR all works as it's looks .I need help with 2 things. Im pretty sure all 4 gas spheres( similar to Citroen with hydroactive suspension )dont have enough Nitrogen pressure and Im looking to buy 4 speheres after regeneration or refuel mine. And second problem Im trying to find Consult in my car and REALLy cant..I spoke 2 days with 2 different AI and they are giving me excluding answers. I found some of this car models DONT HAVE it.. AT ALL- I dont have any problem - nothing flash but I want to have possibility to diagnose my car if anything happend.Would be nice if some one of You have more experience with this BEAUTY and can help me. Here is How its look: here is small clip with my BEAUTY NISSAN
  24. You could try IceBox Autos who make units to specifically fit your car
  25. Our 2018 Micra K14 does not have the Carplay unit fitted which is annoying my wife who is the main driver. Does anyone please know if there is a aftermarket Carplay unit that actually works that we can have fitted to this vehicle?
  26. I would suspect it is the brake pads moving backwards and forwards - usually happens if the pads fitting kit is missing and allows the pads to move in the carrier. If it was the driveshaft joint then it would be constantly be clicking on acceleration and deceleration
