sundeep joined the community
Trieze joined the community
chris gould joined the community
Chris Schmitt joined the community
Michael simpson joined the community
iago joined the community
Gill joined the community
VISSOLTA joined the community
The truck has been sold.
FrankNL joined the community
I would suspect it is the brake pads moving backwards and forwards - usually happens if the pads fitting kit is missing and allows the pads to move in the carrier. If it was the driveshaft joint then it would be constantly be clicking on acceleration and deceleration
