Hi, my qashqai has developed a interior fan problem the last few days, air con , heat, cold ,whichever use there is a clicking noise coming from inside the system , does anyone have any ideas what could be wrong please
James 3006 joined the community
Matt1320 started following Heater resistor location
Hi Everyone The heater on my 09 Pixo only works on 4 so I'm replacing the heater resistor, what's the best way to access it please ? I'm thinking by taking out the glovebox ? Many thanks indeed Matt
Matt1320 joined the community
ukcostis joined the community
Magnifico nismo joined the community
Magnifico joined the community
MrMiles started following K11 Micra Coil pack Rev gauge install issue
Hey folks. Been trying to fit a rev gauge, I followed a video that has the exact same gauge but isn't working correctly. It has power and does it's little calibration when I turn on the ignition, but when the engine is running the needled does not move. Videos show's what I mean. https://videy.co/v?id=FuMqxdoE
MrMiles joined the community
I meant Locking mechanism, not Licking😆
Hi all. I have lost the key to my 2006 Micra Sport. There is an old blade key in the glove compartment(Silly to leave it there, I know). Is it possible to open the door on this model using a bent coathanger by slipping it down and trying to find the licking mechanism? I have done this occasionally with my cars over the years. Thanks in advance. Tony.
Tonyb joined the community
Edward Obrien joined the community
Trevor started following 4wd fault , K12 drivers door lock mechanism removal , Deleted factory data from leaf system diagnose menu and 2 others
Sorry, not a clue but please do let us know how you get on with it -
Possibly some air in the fuel filter .... if it has a priming rubber bulb then this should be firm at all times, if it needs pumping up then you have air trapped in there.
Nissan x trail 1600 2017 model disel
Trevor replied to Richard dack's topic in General Nissan Owners Lounge
Thanks for sharing the solution for this issue....pretty sure other members may have suffered this one and taken to the dealers for an expensive reset -
First point would be to check all earth points on the underside of the vehicle.....have had issues with Nissan's suffering from broken earth straps from the battery to the chassis and transmission
So my 2006 Navara has a 4wd fault. It started off as 2 wheel drive engaged and showing on dash as engaged to now led symbol flashing with 4lo flashing whilst in park (auto) and hand brake on. ATP light also on. When selecting drive, ATP light goes off and 4wd warning light comes on. All three transfer switches have been replaced and transfer actuator. All relays replaced and the two 10 amp fuses under bonnet replaced. There doesn't seem to be any power going to actuator,.but there is power going to the 3 transfer switch plugs. Any other advise would be great...
alex joined the community
Thanks for replying. new clutch in, it had already been making sound for sometime so just did it rather then waiting for it to completely!
MarkPurkiss joined the community
I recently heard a rattling coming from the front of my 2016 note & discovered the bonnet 'stay' to have come loose from its clip on the bonnet. Put tape around stay but its come adrift again. -
Hi all. I have a 2017 xtrail 1600 and last week a message came up on the dash. Oil change 100 miles. So no problem carried on driving and a new message said auto stop start problem not working and the power started to drop of when trying to accelerate. I looked on Internet to try and find problem with no luck. But then I found a thread about if your nissan is coming up for an oil change it can make the start stop not work and turn on the engine light yellow or red. When I purchased the car from sparshatts at millbrook Road Southampton they renewed oil and filter but didn't reset service intefall so the cpu must has said gone over service period and flashed up stop start problem. The fix was to go into maintenance menu and reset the oil service data to reset. After doing this the car is fine. None of this is in the hand book. Nissan should be more honest about how the software works on their cars to Joe public. I hope this helps.
Trevor started following Nissan Roadside Assistance Cover and Clutch
First thoughts....do you rest your foot on the clutch pedal at all? If so, then you have worn the release bearing and this is the reason for the sound. As long as it doesn't get any worse then it should still be good for a while
