Jenno007 joined the community
ENGINE SWAP Can a QG 1.8L (silver top) engine be transferred from a manual N16 to an automatic? Do the crank bolts line up eg. manual flywheel v auto flex plate?
Adey started following RADIO LOCK CODE
Hi I've had my 53reg 1.6 Auto Almera for a couple of years now and the battery went flat the other day. the radio now asks for me to input a code and i don't have this in any of my paperwork. the serial number is CL052930116328 I would appreciate any assistance
Qayyum joined the community
Adey joined the community
Nissan Almera radio code
Adey replied to bboysmax's topic in Nissan Audio / Video / Electronics / Security
Hi I've had my 53reg 1.6 Auto Almera for a couple of years now and the battery went flat the other day. the radio now asks for me to input a code and i don't have this in any of my paperwork. the serial number is CL052930116328 I would appreciate any assistance -
Radio locked joined the community
My radio is locked part no 7 612 830 050 nissan no 25915BH20B can any one help
I need the above for a November 1989 Nissan Sunny 1.4 Any suggestions where I might find them please Many thanks
Matt Hartley joined the community
hmalkoc61 joined the community
Boza joined the community
I have a 2015 qashqai with sat nav but have radio issues as soon as you turn volume knob from 0 to 1 it goes full volume out of drivers side speaker only
bkb started following Engine Swap
bkb joined the community
paul c joined the community
have wheel extenders and wondering who knows where i can get arch extenders for mot clearance , pain having to remove the spacers once a year
Trevor started following New member Hello all , K11 Micra Coil pack Rev gauge install issue , Interior fan problem and 3 others
Trevor replied to MrMiles's topic in Micra Club's Topics
Seems like the connections may be the wrong way round (possibly?) -
Has anything dropped into the heater motor from the dashboard vents by the screen? Also, remove the cabin filter and see if the vents have dragged anything into the blower motor through there
I would definitely start with the glovebox which should then give you a better view of the heater motor and resistor pack
There are several methods to gain entry without damage....although never really tried any of them One is using half a tennis ball over the lock but can't see how that would work Bent coat hanger is probably the best method ..... have a look on YouTube for any instructional videos
I would take it back to the dealer immediately for a check on the software. Seem to recall reading there is an issue on this system
Hi....welcome to the Forums Good to have you onboard!
craig langley joined the community
Hi - can anyone tell me if part number 4911050N11 will work as the OEM part number is 4911050M11 thanks Craig
Hi has anyone had a problem with the E-pedal intermittently not working almost causing me to run into the back of the car in front.. This has happened several times and is terrifying!
Hi everyone I'm a new member
Hi, my qashqai has developed a interior fan problem the last few days, air con , heat, cold ,whichever use there is a clicking noise coming from inside the system , does anyone have any ideas what could be wrong please
Matt1320 started following Heater resistor location
Hi Everyone The heater on my 09 Pixo only works on 4 so I'm replacing the heater resistor, what's the best way to access it please ? I'm thinking by taking out the glovebox ? Many thanks indeed Matt
MrMiles started following K11 Micra Coil pack Rev gauge install issue
Hey folks. Been trying to fit a rev gauge, I followed a video that has the exact same gauge but isn't working correctly. It has power and does it's little calibration when I turn on the ignition, but when the engine is running the needled does not move. Videos show's what I mean. https://videy.co/v?id=FuMqxdoE
I meant Locking mechanism, not Licking😆
Hi all. I have lost the key to my 2006 Micra Sport. There is an old blade key in the glove compartment(Silly to leave it there, I know). Is it possible to open the door on this model using a bent coathanger by slipping it down and trying to find the licking mechanism? I have done this occasionally with my cars over the years. Thanks in advance. Tony.
Deleted factory data from leaf system diagnose menu
Sorry, not a clue but please do let us know how you get on with it
