SithDowell
  1. Problem solved. Renault use 19mm hex M12 X 1.5 wheel bolts. Job's a good 'un!
  2. Hey Trever, thanks for replying! Yeah, I think you're right...I just found out k11 wheel bolts are 19mm and it seems the k12 bolts are smaller. The threads are different too: K11 = M12 X 1.25 K12 = M12 X 1.5 ...so o can't just whack in some K11 bolts instead. Baws! No photos the noo, but I'll see what I can do tomorrow. Thanks again :)
  3. Hey hey, I have a k12 Micra and swapped to 15" X 6.5" Clio wheels (they fill out the arches better, there's more tyre sizes available, and they look grand). I want to finish them off with the 7" center hubcaps from K11 Micra steel wheels. From what I can see, they just push onto the wheel bolts (and since the K11 and K12 have the same PCD it shouldn't be a problem), but after trying them on they don't seem to 'click' into place. They're loose and come off reallyreally easy. Should I use K11 wheel bolts? Or is there a special kind of fitment bracket on K11 wheels that holds the hubcaps in place? Thanks for your time, Sith
  4. Awrite troops... New member here. I inherited a Micra from a relative around 8 months ago and have been continually pleasantly surprised by it. Will post for help elsewhere, just wanted to introduce myself first. Orra best, Sith
