April 25, 20232 yr 2011 Micra K13 problem with fob needing to be pressed twice to open all doors and boot Car used to open with one press to open and one press to close all doors any help apricated Thanks All Bob
April 26, 20232 yr Worth having the battery changed as it could be getting a bit low Also, I believe there may be an issue with the microswitches becoming detached from the circuit board inside the fob. If you take it into a locksmiths that can change the battery they should be able to tell you if this is the case
July 21, 20232 yr At least you can try to replace the battery yourself, if not, then the problem is probably in the wiring
