Posted May 21, 20232 yr It is not obvious from the Hayes manual how you remove the passenger side fascia panel to access the clock. Can anyone advise? Regards Peter C. (1986 Nissan Cherry Spirit GS 1270cc)
May 26, 20232 yr If no screws are obvious to see when you are looking at the panel then it would more than likely be held by clips and gently pulling the panel should release it
