August 5, 20232 yr Hello all... Recently had to change my 2015 pulsar battery after it died, since discovered that while the fans in the car work, they will not rotate to other fans when changing the mode, the just come through the front fans so the car steams up a lot.. also no heat either since the battery was changed, seems to be stuck at the same temp. Any ideas what could have caused this? 😅 at a bit of a loss haha Many thanks, Natalie
August 7, 20232 yr Maybe worth disconnecting the battery and leaving for about half hour then reconnect. Sometimes the electrical system can fall over itself and needs a reboot Start there and then try the controls once more
