August 22, 20232 yr Hi everyone. I own a 2001 r50 and I wish to install 2.5’ lift spacers but I don’t know if I have to buy shocks or any other parts for the mod. I’m not that into mechanical stuff so I’ll just do it with my local mechanic. I mainly use it for daily drive and very little off roading. I just want it to be higher. My English is not that good so I would appreciate if you could explain it in the simplest way possible. Thanks!
August 25, 20232 yr I think the vehicle should take 2.5" spacers and when the weight it down on the shocks then it should be fine....only one way to find out though 🙂
