Posted February 5, 20241 yr It's throwing these codes wondering if there a specific one I need to start with. P0430 P0340 P1446 P0301
February 6, 20241 yr I would say, definitely start with P0301 as the misfire is causing the others to pop up Also the cam sensor could be the cause. Maybe because the timing chain/belt is loose/worn ?
