Engine problems
I have problems with my Pathfinder 2012 mod.
V6 engine v9x crank but not start, bleed the fuel system with the originale pump, the are comming small air bobbels.
I use the car and park him in my driveway and he want start again
  • 3 weeks later...
Sounds like the primer diaphragm might have a slight leak and is drawing air into the fuel filter housing.
I would source a replacement primer head and replace the fuel filter at the same time
