Hi
I have a 2017 Nissan Qashqai J11 St auto petrol model.  The orange malfunction indicator light has been on for a while now.  I have had the vehicle several times to an auto electrician who has reset it and the code was P0303 with the message that the 3rd cylinder is fisfiring.
I have also had it to the local Nissan dealer who again reset it with the same error code showing up.  It has had a new coil ignition pack put in as well as a standard service with new spark plugs.
It has recently started to shudder a bit when driving and the motor has cut out and stopped when I am stationery.  It restarts again when I turn it over.  I have taken it to another mechanic and they have swapped the 3rd and 4th injectors to see it that would make a difference.  The malfunction light has stayed off, however they got me to take the car on a drive at a speed of 100klms to see what happened.  In doing this, the light came back on for a few seconds and went off again but the motor cut out again when I stopped at an intersection.  They have rescanned it again and it is now showing that the 4th cylinder is fisfiring which indicates that the injector/s need replacing.
Just wondering if anyone else has had this situation before and what the outcome was.
Thank you.
Debbie.  Queensland
