Monday at 07:09 PM2 days Hi GuysLooking for VIN number Location, I have the one on the windscreen and the one on the inside of the door, i have looked on the Chassisunder neath as you open the driver's door,and its not there, is there any other place it can be?Your Help would be appreciated Thanks.
Tuesday at 08:43 AM2 days It's on the chassis rail right hand side (outer) under the drivers door. Literally bend down and you should see it straight under the sill.Found this on a Navara site, also it should be on the body below the windscreen area but if all else fails it will be printed on your vehicle logbook
Tuesday at 04:51 PM1 day Author Hi Trevor Thank for your reply but i have looked there and its not on it.
1 hour ago1 hr Unless the chassis has been replaced as they suffered from the rear section (load area) breaking in half?https://www.google.com/search?client=safari&rls=en&q=nissan+navara+chassis&ie=UTF-8&oe=UTF-8https://www.google.com/search?client=safari&rls=en&q=nissan+navara+chassis+number+location&ie=UTF-8&oe=UTF-8
