December 5, 2025Dec 5 Hi folks! I'm driving to France so need to put on some beam deflectors on my Qashqai 2021. I've bought Eurolites, and having read the instructions I understand that I need to apply them using picture 146 but to be honest, I really don't understand where to stick them! (Also they're not the same position on both lights 🙄) . I've been looking, but can't find, any photos of beam deflectors on Qashqais so I can copy. Can anyone help?? Am I the only one who finds this difficult? Any advice gratefully received. TY
December 5, 2025Dec 5 Hi RoseAre you likely to be driving at night? If yes then they should go on the nearside (passenger side) but yes your right, its not easy. I drive without them as I have flat LED but if you want to be legal then stick them on.Have you tried Youtube?
December 5, 2025Dec 5 Author 13 minutes ago, Steve said:Hi RoseAre you likely to be driving at night? If yes then they should go on the nearside (passenger side) but yes your right, its not easy. I drive without them as I have flat LED but if you want to be legal then stick them on.Have you tried Youtube?Thanks for replying! Um, yes, I got square eyes looking on Youtube and found nothing. Hence my message on here. 🙅♀️
December 7, 2025Dec 7 Author On 12/5/2025 at 6:18 PM, Steve said:will you be driving at night?YES! Night ferry ....
December 9, 2025Dec 9 You could try covering the beam pattern in the correct portion of the headlamp with cardboard (and bluetack) before fitting the stickers.This way you can see if the beam pattern is no longer pointing to the kerb (UK spec lights) and it doesn't necessarily have to deflect it to the other side but just not dazzling the oncoming traffic.This means it may reduce your vision on the kerbside (European spec lights) but at least you are legal.
