- Service on Maidstone
Hi from ireland
P0356 error code
O7 nissan pulsar evaporater
- Leaking sunroof drain
This would be transmission drag generated by the various components in the transfer box being rotated with one or more wheels on the ground. Equally there is transmission wind-up which can be dangerous if undoing wheel nuts and the wheel is free to turn with tremendous force which can break an arm so be careful if the car has been driven around on tarmac and with sharp turning (such as driving onto a driveway).- Earlier
- Hello From italy
Ciao Riki Enjoy the Xtrail my friend. Happy new year! - Leaking sunroof drain
