The X-TRAIL e-POWER N-Connecta is a petrol/petrol hybrid - Today
I had the same problem radio cutting off there is a fee upgrade from nissan now work perfectly it's a common problem - Earlier
Welcome to the Club
Xenon Headlights
You should be able to find a set of halogen headlamps which are completely different to Xenon type Try Partsfinder or eBay to see if there is a pair for sale
