Thanks for your reply, This is what I have tried to put in, but as soon as I input my Registration Number for a quote, it automatically fills in Electric in the field, and I’m unable to change it -I can’t find anywhere to put petrol hybrid in the insurance search sites! - Today
I had the same problem radio cutting off there is a fee upgrade from nissan now work perfectly it's a common problem - Earlier
Welcome to the Club
