Well after the influx of msg on here š I bit the bullet and bought 3 new coil packs. Turns out the readings I gave above are correct and I didnāt need the 150 quids worth of coil packs.
The truck has been sold.
Kind of resolved this now a bit. It still has a slightly rough idle in my opinion but it is a 3 cylinder so could just be the nature of the car?? any way I metered out the coil packs all seem to be the same and as I donāt know what they are supposed to be Iām going with they are ok? I also unplugged them one by one and the engine started to misfire as expected. I removed the throttle Body and gave it a good clean. It wasnāt too bad but there was a little bit of oil in there. I also unplugged the fuel solenoid purge valve and let it run for a second or so and plugged it back in. I also found that both battery terminals were very loose! So they got tightened up as well. Since doing this it seems to idle better. The only time the revs seem to hunt is when the ac is on now and the highest it goes is up to about a 1000 when the clutch kicks in which Iād kind of expect as there is extra load on the engine.
So, here's the saga. Offside Drum collapsed inside, my fault- long story. Anyway, new drums, studs, bearings, shoes, spring kit purchased, but could I find an ABS ring for the pixo anywhere? Nope! Eventually, Vertu Nissan offered me 2 rings for Ā£201!!! Bought 2 used drums, cleaned/painted and fitted. ABS light turned off š Moral of the story: Parts like this are becoming very difficult to get. Also, does anyone have any ABS rings? I have 2 brand new drums, with new bearings pressed in and ready to. They'll need the fings fitted, obviously. You can have them both for Ā£50 plus whatever the p&p will be Tony
Hi, my mum has a 2005 Micra, she doesnāt want to sell it, ever. It has c40k mileage and drives like a dream! But, the tailgate switch has failed and Iām struggling to get a replacement - itās the intelligent key version - part number 25380AX10B. Any ideas please?? There loads of the 25380AX60B but these arenāt compatible with the intelligent key. Thanks in anticipation!
I am really sorry to hear that -sadly you donāt have dig deep to see lots of other people in the same boat. I am afraid I found Nissan completely awful to deal with- I really hope you have better luck as we have lost thousands. Citizens advice suggested approaching the car finance company if you have a finance deal because claims can be made outside the warranty of the vehicle. Trading standards are also worth contacting - the more of us who contact the DVSA with evidence I think the better - because engine failure without warning is very dangerous, particularly as this is such a popular family car. I am planning on sending details about this issue to car journalists. I hope you get a happier resolution.- 6 replies
Hi....and welcome to the Club
