  2. Well after the influx of msg on here šŸ˜’ I bit the bullet and bought 3 new coil packs. Turns out the readings I gave above are correct and I didn’t need the 150 quids worth of coil packs.
  3. The truck has been sold.
  4. Kind of resolved this now a bit. It still has a slightly rough idle in my opinion but it is a 3 cylinder so could just be the nature of the car?? any way I metered out the coil packs all seem to be the same and as I don’t know what they are supposed to be I’m going with they are ok? I also unplugged them one by one and the engine started to misfire as expected. I removed the throttle Body and gave it a good clean. It wasn’t too bad but there was a little bit of oil in there. I also unplugged the fuel solenoid purge valve and let it run for a second or so and plugged it back in. I also found that both battery terminals were very loose! So they got tightened up as well. Since doing this it seems to idle better. The only time the revs seem to hunt is when the ac is on now and the highest it goes is up to about a 1000 when the clutch kicks in which I’d kind of expect as there is extra load on the engine.
  6. hi all does anybody know how to check fault codes on a 2017 nissan micra K13 x 1.2 litre petrol i have 2 scanners ( cheapies ) which reads my kia fine but this nissan cant connect to ECU
  7. Hi. I have a qashqai j11 2016 n connecta. A couple of days ago I turned on the radio and no sound. I have tried a reset but no joy. I rang nissan dealer they wanted £150 to diagnose. And if I need a new headunit it's £3000 thats three thousand not a typo lol. Has any got any ideas. A friend suggested a memory fuse gone in the unit but I can't find one listed. Any ideas welcome.
  8. Earlier
  9. My son is the proud new owner of a 2006 X-Trail T-30 as his first vehicle. Generally, it's in great condition, but it does need some bodywork to deal with rust. We are seeking recommendations on where to look online for replacement parts, ideally in Canada but open to internal suggestions. Specifically: Left Quarter Extension Left Quarter Reinforcement Thank you in advance for any advice or experiences.
  10. Hi all, Stuart hers from Scotland and I have just purchased a 2013 Qashqai tekna 1.5 diesel with 71k on clock. I will be using this car to drive to Spain and wondering if there is anything I need to address before I start the journey. Many thanks, Stuart.
  11. Firstly thanks to admin et all for the inclusion of your forum ...... Had a Navara some years back ... dreaded chassis issue and managed a buy back from Nissan Nordics as I live in Sweden. .. Just bought a 2018 NV300 and am trying to remove the drivers arm rest to fit an aftermarket seat cover... centre cap removed and a plastic long squared centre piece revealed.... any clue on how to remove please?... Have put grips on it and tried to ease it free and even put a shifter on it to hopefully slacken it off .... but to to avail ....any one had any experience with this that they could pass on valuable info? Thank you in advance Dox
  12. hi Because I am very happy owner of Nissan Cima 2010 VIP model I imported another Nissan ..now classic 1994(late model from September) very rare with Automatic ACTSUS system. and here is a little clip with my Nissan. NEAR all works as it's looks .I need help with 2 things. Im pretty sure all 4 gas spheres( similar to Citroen with hydroactive suspension )dont have enough Nitrogen pressure and Im looking to buy 4 speheres after regeneration or refuel mine. And second problem Im trying to find Consult in my car and REALLy cant..I spoke 2 days with 2 different AI and they are giving me excluding answers. I found some of this car models DONT HAVE it.. AT ALL- I dont have any problem - nothing flash but I want to have possibility to diagnose my car if anything happend.Would be nice if some one of You have more experience with this BEAUTY and can help me. Here is How its look: here is small clip with my BEAUTY NISSAN
  13. I would suspect it is the brake pads moving backwards and forwards - usually happens if the pads fitting kit is missing and allows the pads to move in the carrier. If it was the driveshaft joint then it would be constantly be clicking on acceleration and deceleration
  14. Did you resolve the issue? I was thinking it may be the Dual Mass Flywheel (if manual transmission) starting to break up Usually noticeable when switching the engine on/off when it will start to rattle
  15. a quick search with Google Lens reveals some results Just right click over the image above and select search with Google Lens and it brings up results of products that roughly match the clips you're looking for
  16. So, here's the saga. Offside Drum collapsed inside, my fault- long story. Anyway, new drums, studs, bearings, shoes, spring kit purchased, but could I find an ABS ring for the pixo anywhere? Nope! Eventually, Vertu Nissan offered me 2 rings for Ā£201!!! Bought 2 used drums, cleaned/painted and fitted. ABS light turned off šŸ‘ Moral of the story: Parts like this are becoming very difficult to get. Also, does anyone have any ABS rings? I have 2 brand new drums, with new bearings pressed in and ready to. They'll need the fings fitted, obviously. You can have them both for Ā£50 plus whatever the p&p will be Tony
      • 1
      • Like
  17. occasionally i get a noise from the o/s/r of my car and a red warning light flashes briefly on the dash(i think it is a master warning light) .After a second the light and noise disappear and everything is ok. Performance and braking are not affected . The noise sounds a bit like ABS Working . Had rear pads replaced and a recent Mot all ok. Noise returned briefly a couple of days ago again just for a second .Usually happens on or near a corner .Any ideas???
  18. Hi, my mum has a 2005 Micra, she doesn’t want to sell it, ever. It has c40k mileage and drives like a dream! But, the tailgate switch has failed and I’m struggling to get a replacement - it’s the intelligent key version - part number 25380AX10B. Any ideas please?? There loads of the 25380AX60B but these aren’t compatible with the intelligent key. Thanks in anticipation!
  19. Hi, my mum has a 2005 Micra, she doesn’t want to sell it, ever. It has c40k mileage and drives like a dream! But, the tailgate switch has failed and I’m struggling to get a replacement - it’s the intelligent key version - part number 25380AX10B. Any ideas please?? There loads of the 25380AX60B but these aren’t compatible with the intelligent key. Thanks in anticipation!
  20. I am really sorry to hear that -sadly you don’t have dig deep to see lots of other people in the same boat. I am afraid I found Nissan completely awful to deal with- I really hope you have better luck as we have lost thousands. Citizens advice suggested approaching the car finance company if you have a finance deal because claims can be made outside the warranty of the vehicle. Trading standards are also worth contacting - the more of us who contact the DVSA with evidence I think the better - because engine failure without warning is very dangerous, particularly as this is such a popular family car. I am planning on sending details about this issue to car journalists. I hope you get a happier resolution.
  21. Hi, welcome to the Club Good to have you onboard!
  22. you could try running it through Google Lens which may identify the model
  23. I recently got a 2019 Tekna which I'm finding is very "jittery" at low speeds, particularly when cold. Anyone else finding the sane?
  24. Hi everyone I have a 58 plate d40 and have bought a canopy for it my question is how does the mountain top come off my d40 to fit the canopy please. Scot
  25. Hi....and welcome to the Club
  26. Certainly a cheap fix but should it be necessary on a new vehicle?
  27. Hi all. New-to-me owner here - an NP300 N-Guard - picked up 2 weeks ago and still getting to grips with it. Former owner of a T31 X-Trail for 11 years, so sticking with a known and (reasonably) well-trusted brand. Only after purchase and after a 200+ mile drive home did I realise that there was no 'key nut' for the lock-nuts on the tarmac-touching wheels, but a trip to the local dealer sorted that particular issue (at a cost, obviously). In putting the truck in to a local provider of underbody rust protection treatment yesterday. I learned that there was a security lock nut applied to the spare wheel too. Guess what? The key nut required for that, which attaches to a T-bar in the provided toolkit, wasn't anywhere to be found either, so the guy couldn't fully complete his treatment on the underside of the tub. I spoke to both previous owners of the vehicle, and neither could recall having seen nor had need to use that part (nor the key nut for the 'in-use' wheels. Too far down the line to know for sure if they weren't originally provided, or if someone's memory isn't what it should be. However, fact is, if I get a puncture and need to replace a wheel, I'm screwed until I get a key nut to drop the spare wheel. I called the local dealership after talking to the two previous owners. I explained my situation and, of course, a key nut is available to order (again, at cost), but as part of a set replacing the whole set-up, and removing the old part is, according to the parts guy, "tricky, but do-able". He added that the key nut would have to be part of a set 'cos the current lock nut would have a different design. Having looked online at images for the offending parts, it seems that the 'pattern' of the lock and key nuts are the same in every one, and this applies to D40 and NP300 models. Can anyone confirm if this is the case, please? If so, I can get a set off ebay for £20 less than Nissan are charging. Thanks in advance.
