Windscreen wiper control
Oil sensor error visit dealer
Windshield water jug
Thanks for the update chris!!
- Service on Maidstone
Hi from ireland
P0356 error code
O7 nissan pulsar evaporater
- Leaking sunroof drain
Reconditioned transmission would be the best way forwards or if not a secondhand used transmission from a wreckers yard as it may have been replaced before the vehicle was scrapped. Either way, ensure that it is the proper fluid going into the replacement transmission and change regularly (before it is due) - Leaking sunroof drain
