- Service on Maidstone
Hi from ireland
P0356 error code
O7 nissan pulsar evaporater
- Leaking sunroof drain
Hi....welcome to the Club The simplest and most effective and also the cheapest option is to but yourself a Smoke Generator which will instantly identify where the leak is coming from. https://www.ebay.co.uk/itm/315502976341?itmmeta=01KEGZPWYGJ259PS400VMKP27X&hash=item4975715d55 All you need to do is place it in the area where the leak is coming from and unlike water (which tracks to the lowest point from where it is leaking) the smoke goes directly out of the point of entry of the leak. At a cost of £65 and it is something you can do yourself then it negates paying £700 for the diagnosis and more than likely you can repair it yourself. Let us know how you get on with it- Earlier
- Nissan Note service reset
- Hello From italy
Ciao Riki Enjoy the Xtrail my friend. Happy new year! - Leaking sunroof drain
