  2. Hi , mithering old pensioner hither. Does any fellow Qashqai driver know of any training classes or just help from the dealers to understand how to drive it safely. Bearing in mind we struggle with our mobile phones. Help please
  3. Hi everybody just in the process of buying 2022 Qashqai, any tips to ask at the sale
  4. Yesterday
  5. Been told by Nissan dealer after 60, 000 mile service that the front ball joint rubbers have split. No mention of issue with the bearings. Not too bad I thought. They say the part comes in one bit and have quoted me £1200 to replace them. Is this reasonable. Customer at the next desk to me appeared to have the same issue
  6. I'm sure you will keep finding bodges throughout the car and maybe worthwhile assuming everything needs checking and just work your way through it. If you are lucky you may find the issue which is causing the problems and may not cost you much if anything at all to resolve Let us know how you get on with it
  7. Last week
  8. Please let us know how you get on with it
  9. Thanks. I’ll check it out
  10. Thanks all - found out extra security not needed. Closed topic
  11. Unless the chassis has been replaced as they suffered from the rear section (load area) breaking in half? https://www.google.com/search?client=safari&rls=en&q=nissan+navara+chassis&ie=UTF-8&oe=UTF-8 https://www.google.com/search?client=safari&rls=en&q=nissan+navara+chassis+number+location&ie=UTF-8&oe=UTF-8
  12. Well the induction hose you replaced was definitely the culprit and as that was perished I would also look for any other hoses that may have holes or splits through perishing over the years. An increase in revs is usually a vacuum leak through a perished or split hose. As for the transmission - it is hard to tell what the issue is but I would advise to get it to a transmission specialist for them to set it up correctly - may need calibration through specialist equipment
  13. Earlier
  14. Personally I would direct compressed air around the area to see if I could clean it without removing components - you can get compressed air canisters to clean computers and keyboards. The possibly I would lightly apply some silicone spray around the area the noise is coming from but not too much, only a fine spray so as not to interfere with the SRS components.
  15. Sometimes helps to breakdown carbon deposits but mainly using premium high octane/cetane fuels is best to help with cleaning up the combustion process.
  16. Hi...welcome to the Club Just do the bits that you can arrange to sort over time (wiper blades, tyres, etc) and just keep on top of servicing and any other issues that may crop up. Feel free to ask questions whenever you need advice
  17. I use a smart screen with Android Auto. Then connect my phone via BlueTooth and use Waze map. Less expensive and live updates of accidents, traffic jams etc.
  18. Hi All We can confirm our seasonal opening hours will be as follows: Up until the 19thDecember: Normal hours. Saturday 20th December: Closed Sunday 21st December: Closed Monday 22nd December: 9.00am – 3.00pm Tuesday 23rd December: 9.00am – 3.00pm Christmas Eve: 9.00am – 3.00pm Christmas Day: Closed Boxing Day: Closed Saturday 27th December: Closed Sunday 28th December: Closed Monday 29th December: 9.00am – 3.00pm Tuesday 30th December: 9.00am – 3.00pm New Years Eve: 9.00am – 3.00pm New Years Day: Closed Friday 2nd January: 9.00am – 3.00pm Saturday 3rd January: Normal Hours Resume. Regards, Dan
  19. I can only really find springs which will drop the height but not sure about other suspension components to complement the springs (dampers, links, etc) https://www.lkperformance.co.uk/car-parts/suspension/lowering-springs/nissan/pathfinder
  20. This is quite normal as it dims everything for nighttime driving. If you have the infotainment screen fitted then this also dims as well
  21. There was I thinking a System Fault must be serious but after some delving into the reams of paper that make up the Leaf owners book, I find that it is nothing major after all. I think one of the radars giving blind spot protection must have failed because switching off all of these functions the warning has gone! I don't think I will bother to do anything about this as if there was one function I would consider completely uneccessary in a car it would be this. The electronics systems fitted in modern cars, to my mind , is ridiculous. I suppose it is all leading up to when the human driver is superfluous? I also wish Nissan would include a manual that is specific to the actual model to which is it issued it is very confusing to have a manual that has all the items fitted to all models and nothing to indicate what is not fitted to a particular car! I am considering purchasing one of those OBDs, the Topdon Carpal looks like a good contender but I could not find anything on their website to see if it can diagnose faults in a Nissan Leaf. Perhaps there is someone on this site that would know?
  22. UK-SRi replied to VG1's topic in Infiniti
  23. Sounds like they have arrived a diagnostic conclusion which seems quite reasonable. Not sure why it cuts out though, but sometimes this can occur when the engine revs 'stumble' Please let us know how it all goes
  24. I used Lens on my old Alphard years ago.. worked a treat. once settings set up then let it be.
  25. Hi....welcome to the Club Please let us know how you get on with it all Good to have you onboard
  26. Hi .... welcome to the Club Nice collection of cars - good to have you onboard
  27. Only done 10 miles but loving it already. We did have a Kadjar as a company car for 2 years so I had an idea of what it would be like.
  28. Not on late models as it an EU requirement as I understand it. Mine is set up with a shortcut to turn audio warning off by pressing control switch and Okay.
  29. LAL posted a topic in Nissan Pathfinder Forum
