  2. Certainly a cheap fix but should it be necessary on a new vehicle?
  4. Just joined. So thought I'd say hello from sunny (lol) Southend on Sea.
  6. Hi all. New-to-me owner here - an NP300 N-Guard - picked up 2 weeks ago and still getting to grips with it. Former owner of a T31 X-Trail for 11 years, so sticking with a known and (reasonably) well-trusted brand. Only after purchase and after a 200+ mile drive home did I realise that there was no 'key nut' for the lock-nuts on the tarmac-touching wheels, but a trip to the local dealer sorted that particular issue (at a cost, obviously). In putting the truck in to a local provider of underbody rust protection treatment yesterday. I learned that there was a security lock nut applied to the spare wheel too. Guess what? The key nut required for that, which attaches to a T-bar in the provided toolkit, wasn't anywhere to be found either, so the guy couldn't fully complete his treatment on the underside of the tub. I spoke to both previous owners of the vehicle, and neither could recall having seen nor had need to use that part (nor the key nut for the 'in-use' wheels. Too far down the line to know for sure if they weren't originally provided, or if someone's memory isn't what it should be. However, fact is, if I get a puncture and need to replace a wheel, I'm screwed until I get a key nut to drop the spare wheel. I called the local dealership after talking to the two previous owners. I explained my situation and, of course, a key nut is available to order (again, at cost), but as part of a set replacing the whole set-up, and removing the old part is, according to the parts guy, "tricky, but do-able". He added that the key nut would have to be part of a set 'cos the current lock nut would have a different design. Having looked online at images for the offending parts, it seems that the 'pattern' of the lock and key nuts are the same in every one, and this applies to D40 and NP300 models. Can anyone confirm if this is the case, please? If so, I can get a set off ebay for £20 less than Nissan are charging. Thanks in advance.
  7. I have a nissan qashqai j11 reversing problem. When I put in reverse and try to move the engine stop, it is a manual diesel stop start.
  8. Hi. If you need any help with insurance at all then please feel free to drop me a line. Regards, Dan.
  9. I'm having problems removing my wheels, having taken out the 4 wheel bolts the wheel seems to be stuck to the hub of the wheel. Any help please.
  10. I need new wiper blades for my 2020 K14 Micra because the current ones put smudges on my windshield. Please Give me some suggestions
  11. I have programmed fobs in the past and they have to be programmed at the same time rather than doing it later as it is opened for programming within the timeframe
  12. If it were me I would go over everything I have touched and ensure it is not damaged (as much as you can determine) and that there is nothing interfering with the component or wiring coming from it. This has worked many times for me when I have been in a rush and not noticed something simple
  13. It looks like a damper for the throttle, EGR or similar
  14. Hi Rob.....welcome to the club Good to have you onboard!
  15. Hi Sid....welcome to the Club The Sunny looks in amazing condition - so rare on the roads now Good to have you onboard
  16. I had the same problem radio cutting off there is a fee upgrade from nissan now work perfectly it's a common problem
  17. Earlier
  18. I own a 1.5dci Nissan pulsar 2015, and I want to change the CD player with a satnav unit. I was wondering if if anyone could help me find a wiring diagram for it as one of the original plugs doesn't fit into the new unit. I've had a look around and couldn't find one. Can anyone please help me?
  19. Hi enzso ....welcome to the club There is a reset procedure for the CVT transmission which may benefit you. CM (Transmission Control Module) reset by cycling the ignition and pressing the accelerator pedal, or disconnecting the battery. https://www.google.com/search?q=nissan+k13+automatic+gearbox+reset&rlz=1C5MACD_en&oq=nissan+k13+automatic+gearbox+reset&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRigAdIBCTE0NzQ0ajBqN6gCALACAA&sourceid=chrome&ie=UTF-8 There are also videos on how to reset the transmission in this search link (above)
  20. Does anyone know where to find rear right door glass for 1984 n11 4door cherry? Help please
  21. OK, I've managed to sort it now.
  22. It's on my trailer. I want to get another as a spare wheel. Tyre size is 165 R13C. What car does it come off?
  23. In September 2024 I bought a brand-new Qashqai e-power when the weather went below 5° the car would not start the dashboard would not come on after many times trying to start it would eventually start one morning it would not start and my foot slipped off the break onto the accelerator and I could hear the engine come on but the dashboard remain off after going through five diagnostic checks and the dealer saying that there’s nothing wrong with the car eventually they decided after seven months to change the instrument panel on the dashboard now we have to wait till September October when the weather gets cold to see whether it worked or not I’m sure that i’m the only one that is experiencing is happening too
  24. Many thanks for this. Really helpful reply. Greg
  25. try Samco hoses - they are silicon and can be made to length and shape https://samcosport.com/car/
  26. I’m looking for a radiator for our scargo, damaged is ok providing the bottom tank is ok many thanks
  27. Hi all, I am the third owner of my 1994 Nissan Altima. I'm looking to get some help and advice on repairs that it needs. Can somebody point me in the right direction to which forum I would use I don't really see a Nissan Altima forum. Alternatively I could just say what's wrong with it here. I need to swap out the knock sensor and I'm not really sure how to get to it. If anybody knows the procedure I would be grateful. The knock sensor is behind the engine below the intake manifold.
  28. Hi all, I’m trying to replace the alternator on my 2017 Nissan Micra K14 Visia 1.0L (71PS – HR10DE engine), but I’ve hit a wall trying to get the belt off. I’ve located the tensioner pulley (the black one just above the alternator), but the centre is smooth — no bolt head or nut — and I can’t for the life of me find where to apply a tool to release the belt tension. I am no mechanic either .... wheels and fluids is usually my limit! I’ve checked above, behind, and around the tensioner pulley but can’t see a square hole or hex boss to rotate the tensioner arm. The engine bay is tight, and I’m not sure if I’m missing something obvious or if access is just that hidden. I’ve tried to follow online guides and videos, but most are for different engines or older models (K12/K13). Photos attached if that helps (can add more if needed). Any help — diagrams, tips, tooling advice — would be massively appreciated before I lose the will to live or call a mechanic 😅 Thanks in advance!
