- Service on Maidstone
Hi from ireland
P0356 error code
O7 nissan pulsar evaporater
- Leaking sunroof drain
I would start with any serviceable items that are overdue, oil, filter, air filter, fuel filter, etc then I would also be checking for the condition of rubber vacuum and breather hoses to see if they are split or perished. This can usually be identified by a hissing noise with the engine running at idle. Replace parts if you find any damage to the hoses or gaskets around the intake system (inlet manifold, etc) Alternatively, it may be something as simple as an exhaust leak - place a rag over the rear silencer tailpipe with the engine at idle speed (outside in the fresh air to avoid carbon monoxide poisoning) and if you hear a hissing from the exhaust front section, manifold or oxygen sensor(s) then that is your fault.- Earlier
- nissan pulsar 2013 C 12 CVT issues - Sydney Australia
- Hello From italy
Ciao Riki Enjoy the Xtrail my friend. Happy new year! - Leaking sunroof drain
