  2. please let us know the results and what it was.. may help other leaf owners Cheers
  3. UK-SRi replied to VG1's topic in Infiniti
  4. Yesterday
  5. I have a 2011 Nissan Pathfinder is there any lower kids for? It
  6. Last week
  7. Hi everybody! Nissan Qashqai 2017 1,6 diesel, cvt. About 86000 miles So the car starts and runs fine, but I noticed a slight knocking upon coldstart. Almost as if the engine is having trouble building oil pressure. For about 4-5 seconds. And I have crankcase pressure opening the oil fillercap + some smoke. So a Pcv problem I thought. Changed the pcv and the knocking upon starting might have been slightly less. But still crankcase pressure. If I disconnect the hose on the pcv and blow in it, there are not resistance. And I can’t find any defects on other hoses. I notice a sound from the airfilter box, as if the engine is sucking air from a leak in the box. Dismantled everything but can’t find any leak. Some oil in the hoses and around the filler cap, but nothing alarming. Haven’t done a compression test as it’s not a high mileage car. Full service book. Drives 40 + 40 miles everyday. Can’t upload film as it’s to big.. Anyone who has experienced the same problem.
  8. Try this company https://www.petrolcaps.co.uk/
  9. Sounds like they have arrived a diagnostic conclusion which seems quite reasonable. Not sure why it cuts out though, but sometimes this can occur when the engine revs 'stumble' Please let us know how it all goes
  10. If it is coming from the interior (e.g. back of the steering wheel) then it could be the SRS rotary coupler as they can suffer from moisture and dirt ingress over time
  11. I used Lens on my old Alphard years ago.. worked a treat. once settings set up then let it be.
  12. Hi....welcome to the Club Please let us know how you get on with it all Good to have you onboard
  13. Hi .... welcome to the Club Nice collection of cars - good to have you onboard
  14. Only done 10 miles but loving it already. We did have a Kadjar as a company car for 2 years so I had an idea of what it would be like.
  15. Earlier
  16. Not on late models as it an EU requirement as I understand it. Mine is set up with a shortcut to turn audio warning off by pressing control switch and Okay.
  17. LAL posted a topic in Nissan Pathfinder Forum
  18. welcome to the club !!
  19. Hi Simon...welcome to the Club You certainly have a good collection of Nissans Good to have you onboard
  20. In the UK there is a windscreen company called Autoglass and they have all the equipment and necessary knowledge to set up the ADAS If there is somewhere similar in Sweden that you could take the car to for a check and if necessary get them to set it up correctly
  21. Thanks for the tip, I will check them out. Cheers.
  22. First thing I would have suggested is fitting a new good quality battery. Also, not entirely sure if maybe the stored battery voltage needs resetting with a scan tool
  23. Hi ..... welcome to the Club It's a perfect car for local use more so than motorway but it should be mostly reliable and also economical Enjoy the forums
  24. I bought this: Tuqiang Car Seat Covers For Nissan X- Trail 2014-20 5 Seat Full Set PU Leather but the purchase fell through so it is now up for sale. It is not used. It is listed on ebay https://www.ebay.co.uk/itm/297629455187
  25. I just tried taking down my spare tire to check the air pressure. Needless to say, I don't think it had ever been out. Due to the cold climate (Salted winter roads, Northern Canada), the bolt was very rusty and try as I might, no lube was enough and I snapped the bolt in the "hook" assembly that holds the spare tire carrier up under the car. Does anyone have a usable bolt and hook assembly that they'd be willing to sell?
  26. there are some posts on google search relating to the PO409 code I would first start by running some cleaning solution through the fuel and give the engine a very long high revs run to burn off any excess carbon that has collected in the EGR or Intake Manifold
  27. possibly air mass meter is causing the jerking - try removing, cleaning and replacing Another possible cause could be the throttle pedal sensor needs replacing? Have you turned off the air conditioning as this will run a fan on start up
  28. thanks for updating us and please let us know how it proceeds
  29. Hallo den habe ich erfolgreich eingebaut: L7808 Spannungsregler 8V DC gruss Michael
