  2. Thanks all - found out extra security not needed. Closed topic
  3. Today
  4. Unless the chassis has been replaced as they suffered from the rear section (load area) breaking in half? https://www.google.com/search?client=safari&rls=en&q=nissan+navara+chassis&ie=UTF-8&oe=UTF-8 https://www.google.com/search?client=safari&rls=en&q=nissan+navara+chassis+number+location&ie=UTF-8&oe=UTF-8
  5. Sounds like the timing chain is worn - just posted an article relating to a Nissan Pulsar c13 1.2 DIG-T engine with same symptoms. https://www.nissanownersclub.com/forums/topic/34996-nissan-pulsar-c13-neverending-problem/
  6. Hmm, seems like someone had the issue before and a bodge was carried to rectify the issue (or at least attempt to rectify it). There is an issue with the timing chains and as far as I can see it was a recall from Nissan. It does suggest that it occurs on hard acceleration (e.g. from a slip-road) and if the chain is slack it can drift away from the timing point by a small fraction (much like a loose timing belt) which can then throw a code for cam/crank timing and result in what you are experiencing. I would personally replace the engine oil and look to see what has come out - e.g. metal particles and then replace it with the specified oil which may have not been supplied with previously. https://www.autodoc.co.uk/car-parts/engine-oil-12094/nissan/pulsar/pulsar-hatchback-c13/107484-1-2-dig-t If you use a quality oil of the correct specifications (as listed in the link above) and see if that makes any difference to how it runs. If no real difference is noted then I would advise to get the timing chain replaced which will almost certainly make a difference if it is worn
  7. Last week
  8. Well the induction hose you replaced was definitely the culprit and as that was perished I would also look for any other hoses that may have holes or splits through perishing over the years. An increase in revs is usually a vacuum leak through a perished or split hose. As for the transmission - it is hard to tell what the issue is but I would advise to get it to a transmission specialist for them to set it up correctly - may need calibration through specialist equipment
  9. Personally I would direct compressed air around the area to see if I could clean it without removing components - you can get compressed air canisters to clean computers and keyboards. The possibly I would lightly apply some silicone spray around the area the noise is coming from but not too much, only a fine spray so as not to interfere with the SRS components.
  10. Earlier
  11. Sometimes helps to breakdown carbon deposits but mainly using premium high octane/cetane fuels is best to help with cleaning up the combustion process.
  12. Hi...welcome to the Club Just do the bits that you can arrange to sort over time (wiper blades, tyres, etc) and just keep on top of servicing and any other issues that may crop up. Feel free to ask questions whenever you need advice
  13. I use a smart screen with Android Auto. Then connect my phone via BlueTooth and use Waze map. Less expensive and live updates of accidents, traffic jams etc.
  14. Hi All We can confirm our seasonal opening hours will be as follows: Up until the 19thDecember: Normal hours. Saturday 20th December: Closed Sunday 21st December: Closed Monday 22nd December: 9.00am – 3.00pm Tuesday 23rd December: 9.00am – 3.00pm Christmas Eve: 9.00am – 3.00pm Christmas Day: Closed Boxing Day: Closed Saturday 27th December: Closed Sunday 28th December: Closed Monday 29th December: 9.00am – 3.00pm Tuesday 30th December: 9.00am – 3.00pm New Years Eve: 9.00am – 3.00pm New Years Day: Closed Friday 2nd January: 9.00am – 3.00pm Saturday 3rd January: Normal Hours Resume. Regards, Dan
  15. I can only really find springs which will drop the height but not sure about other suspension components to complement the springs (dampers, links, etc) https://www.lkperformance.co.uk/car-parts/suspension/lowering-springs/nissan/pathfinder
  16. This is quite normal as it dims everything for nighttime driving. If you have the infotainment screen fitted then this also dims as well
  17. There was I thinking a System Fault must be serious but after some delving into the reams of paper that make up the Leaf owners book, I find that it is nothing major after all. I think one of the radars giving blind spot protection must have failed because switching off all of these functions the warning has gone! I don't think I will bother to do anything about this as if there was one function I would consider completely uneccessary in a car it would be this. The electronics systems fitted in modern cars, to my mind , is ridiculous. I suppose it is all leading up to when the human driver is superfluous? I also wish Nissan would include a manual that is specific to the actual model to which is it issued it is very confusing to have a manual that has all the items fitted to all models and nothing to indicate what is not fitted to a particular car! I am considering purchasing one of those OBDs, the Topdon Carpal looks like a good contender but I could not find anything on their website to see if it can diagnose faults in a Nissan Leaf. Perhaps there is someone on this site that would know?
  18. UK-SRi replied to VG1's topic in Infiniti
  19. Sounds like they have arrived a diagnostic conclusion which seems quite reasonable. Not sure why it cuts out though, but sometimes this can occur when the engine revs 'stumble' Please let us know how it all goes
  20. I used Lens on my old Alphard years ago.. worked a treat. once settings set up then let it be.
  21. Hi....welcome to the Club Please let us know how you get on with it all Good to have you onboard
  22. Hi .... welcome to the Club Nice collection of cars - good to have you onboard
  23. Only done 10 miles but loving it already. We did have a Kadjar as a company car for 2 years so I had an idea of what it would be like.
  24. Not on late models as it an EU requirement as I understand it. Mine is set up with a shortcut to turn audio warning off by pressing control switch and Okay.
  25. LAL posted a topic in Nissan Pathfinder Forum
  26. welcome to the club !!
  27. Hi Simon...welcome to the Club You certainly have a good collection of Nissans Good to have you onboard
  28. In the UK there is a windscreen company called Autoglass and they have all the equipment and necessary knowledge to set up the ADAS If there is somewhere similar in Sweden that you could take the car to for a check and if necessary get them to set it up correctly
  29. Thanks for the tip, I will check them out. Cheers.
