  2. I would suspect it is the brake pads moving backwards and forwards - usually happens if the pads fitting kit is missing and allows the pads to move in the carrier. If it was the driveshaft joint then it would be constantly be clicking on acceleration and deceleration
  3. Did you resolve the issue? I was thinking it may be the Dual Mass Flywheel (if manual transmission) starting to break up Usually noticeable when switching the engine on/off when it will start to rattle
  4. a quick search with Google Lens reveals some results Just right click over the image above and select search with Google Lens and it brings up results of products that roughly match the clips you're looking for
  6. So, here's the saga. Offside Drum collapsed inside, my fault- long story. Anyway, new drums, studs, bearings, shoes, spring kit purchased, but could I find an ABS ring for the pixo anywhere? Nope! Eventually, Vertu Nissan offered me 2 rings for £201!!! Bought 2 used drums, cleaned/painted and fitted. ABS light turned off 👍 Moral of the story: Parts like this are becoming very difficult to get. Also, does anyone have any ABS rings? I have 2 brand new drums, with new bearings pressed in and ready to. They'll need the fings fitted, obviously. You can have them both for £50 plus whatever the p&p will be Tony
      • 1
      • Like
  7. occasionally i get a noise from the o/s/r of my car and a red warning light flashes briefly on the dash(i think it is a master warning light) .After a second the light and noise disappear and everything is ok. Performance and braking are not affected . The noise sounds a bit like ABS Working . Had rear pads replaced and a recent Mot all ok. Noise returned briefly a couple of days ago again just for a second .Usually happens on or near a corner .Any ideas???
  8. Hi, my mum has a 2005 Micra, she doesn’t want to sell it, ever. It has c40k mileage and drives like a dream! But, the tailgate switch has failed and I’m struggling to get a replacement - it’s the intelligent key version - part number 25380AX10B. Any ideas please?? There loads of the 25380AX60B but these aren’t compatible with the intelligent key. Thanks in anticipation!
  9. Hi, my mum has a 2005 Micra, she doesn’t want to sell it, ever. It has c40k mileage and drives like a dream! But, the tailgate switch has failed and I’m struggling to get a replacement - it’s the intelligent key version - part number 25380AX10B. Any ideas please?? There loads of the 25380AX60B but these aren’t compatible with the intelligent key. Thanks in anticipation!
  10. I am really sorry to hear that -sadly you don’t have dig deep to see lots of other people in the same boat. I am afraid I found Nissan completely awful to deal with- I really hope you have better luck as we have lost thousands. Citizens advice suggested approaching the car finance company if you have a finance deal because claims can be made outside the warranty of the vehicle. Trading standards are also worth contacting - the more of us who contact the DVSA with evidence I think the better - because engine failure without warning is very dangerous, particularly as this is such a popular family car. I am planning on sending details about this issue to car journalists. I hope you get a happier resolution.
  11. Earlier
  12. Hi, welcome to the Club Good to have you onboard!
  13. you could try running it through Google Lens which may identify the model
  14. I recently got a 2019 Tekna which I'm finding is very "jittery" at low speeds, particularly when cold. Anyone else finding the sane?
  15. Hi everyone I have a 58 plate d40 and have bought a canopy for it my question is how does the mountain top come off my d40 to fit the canopy please. Scot
  16. Hi....and welcome to the Club
  17. Certainly a cheap fix but should it be necessary on a new vehicle?
  18. Hi all. New-to-me owner here - an NP300 N-Guard - picked up 2 weeks ago and still getting to grips with it. Former owner of a T31 X-Trail for 11 years, so sticking with a known and (reasonably) well-trusted brand. Only after purchase and after a 200+ mile drive home did I realise that there was no 'key nut' for the lock-nuts on the tarmac-touching wheels, but a trip to the local dealer sorted that particular issue (at a cost, obviously). In putting the truck in to a local provider of underbody rust protection treatment yesterday. I learned that there was a security lock nut applied to the spare wheel too. Guess what? The key nut required for that, which attaches to a T-bar in the provided toolkit, wasn't anywhere to be found either, so the guy couldn't fully complete his treatment on the underside of the tub. I spoke to both previous owners of the vehicle, and neither could recall having seen nor had need to use that part (nor the key nut for the 'in-use' wheels. Too far down the line to know for sure if they weren't originally provided, or if someone's memory isn't what it should be. However, fact is, if I get a puncture and need to replace a wheel, I'm screwed until I get a key nut to drop the spare wheel. I called the local dealership after talking to the two previous owners. I explained my situation and, of course, a key nut is available to order (again, at cost), but as part of a set replacing the whole set-up, and removing the old part is, according to the parts guy, "tricky, but do-able". He added that the key nut would have to be part of a set 'cos the current lock nut would have a different design. Having looked online at images for the offending parts, it seems that the 'pattern' of the lock and key nuts are the same in every one, and this applies to D40 and NP300 models. Can anyone confirm if this is the case, please? If so, I can get a set off ebay for £20 less than Nissan are charging. Thanks in advance.
  19. I have a nissan qashqai j11 reversing problem. When I put in reverse and try to move the engine stop, it is a manual diesel stop start.
  20. Hi. If you need any help with insurance at all then please feel free to drop me a line. Regards, Dan.
  21. I'm having problems removing my wheels, having taken out the 4 wheel bolts the wheel seems to be stuck to the hub of the wheel. Any help please.
  22. I need new wiper blades for my 2020 K14 Micra because the current ones put smudges on my windshield. Please Give me some suggestions
  23. I have programmed fobs in the past and they have to be programmed at the same time rather than doing it later as it is opened for programming within the timeframe
  24. If it were me I would go over everything I have touched and ensure it is not damaged (as much as you can determine) and that there is nothing interfering with the component or wiring coming from it. This has worked many times for me when I have been in a rush and not noticed something simple
  25. It looks like a damper for the throttle, EGR or similar
  26. Hi Rob.....welcome to the club Good to have you onboard!
  27. Hi Sid....welcome to the Club The Sunny looks in amazing condition - so rare on the roads now Good to have you onboard
