  2. It looks like a damper for the throttle, EGR or similar
  3. Today
  4. Certainly never heard of this before but if that appears to resolve the issue then its an easy (and cheap) fix 🙂
  5. Hi Rob.....welcome to the club Good to have you onboard!
  6. Hi Sid....welcome to the Club The Sunny looks in amazing condition - so rare on the roads now Good to have you onboard
  7. Yesterday
  8. I had the same problem radio cutting off there is a fee upgrade from nissan now work perfectly it's a common problem
  9. Last week
  10. I have a K12 which I bought a few months back. I didnt realise at the time but the air-con does not work! Initially there was no revs increase or fan activation along with no click from the compressor. So the first thing I did was to recharge the system. This fixed the revs increase and fan activation but not the compressor clutch issue. Eventually I ended up at the IDPM and looking at the 10a fuse there which is in tact. I did wonder about the empty relay slot and thought I would move one of the other (fan 1 / 3) relays into the slot to see if that made any difference. It was a struggle to get the relay out so I moved down to the bottom - Relay 9 and tried levering that out with a screw-driver. Of course the screwdriver pierced the casing and I ended up destroying that relay. This left me with a car that turned over but wouldn't start! As I needed the car and had no other relays I could use, I decided to jump the relay as a temporary fix. This worked although has left me with some odd behaviour. Now when the ignition goes off and even with the key removed, the sidelights, rear lights and number plate light come on for around 5-10 minutes before going out. The replacement relay arrived yesterday and I fitted that, it threw a U1001 code and wouldn't start, I cleared the code and tried again but still no joy and the code returned. It did, however fix the odd behaviours I mentioned above! I removed the relay and, again, jumped it so I could drive but the odd behaviour has of course returned although, I am now able to clear the U1001 code permanently. I have a new (second-hand) IPDM on the way and I plan on either using it as a donor to repair the damage I have done and possibly replace the A/C relay inside OR just try to swap the eproms over. Does anyone have any ideas as to what I may have damaged? Ive checked all fuses other than the fusible links and the four coming off the battery terminals. I'll get to those once the new unit arrives. Also, is there any risk of damage running the car as it is now? Any ideas or help would be very gratefully received!
  11. I've just broken one of my two key fobs for my Qashqiai 2011 J10 and I want to get a replacement and program it myself. I've seen a method listed here and on a few other sites. I have a few questions around this: 1. When reprogramming do you have to do the new fob and existing fob as I've read it deletes all saved keys so both need to be programmed together? 2. Is there any issue around the immobiliser with the self programming method? TIA
  12. I own a 1.5dci Nissan pulsar 2015, and I want to change the CD player with a satnav unit. I was wondering if if anyone could help me find a wiring diagram for it as one of the original plugs doesn't fit into the new unit. I've had a look around and couldn't find one. Can anyone please help me?
  13. Earlier
  14. Hi enzso ....welcome to the club There is a reset procedure for the CVT transmission which may benefit you. CM (Transmission Control Module) reset by cycling the ignition and pressing the accelerator pedal, or disconnecting the battery. https://www.google.com/search?q=nissan+k13+automatic+gearbox+reset&rlz=1C5MACD_en&oq=nissan+k13+automatic+gearbox+reset&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRigAdIBCTE0NzQ0ajBqN6gCALACAA&sourceid=chrome&ie=UTF-8 There are also videos on how to reset the transmission in this search link (above)
  15. Does anyone know where to find rear right door glass for 1984 n11 4door cherry? Help please
  16. OK, I've managed to sort it now.
  17. It's on my trailer. I want to get another as a spare wheel. Tyre size is 165 R13C. What car does it come off?
  18. In September 2024 I bought a brand-new Qashqai e-power when the weather went below 5° the car would not start the dashboard would not come on after many times trying to start it would eventually start one morning it would not start and my foot slipped off the break onto the accelerator and I could hear the engine come on but the dashboard remain off after going through five diagnostic checks and the dealer saying that there’s nothing wrong with the car eventually they decided after seven months to change the instrument panel on the dashboard now we have to wait till September October when the weather gets cold to see whether it worked or not I’m sure that i’m the only one that is experiencing is happening too
  19. Many thanks for this. Really helpful reply. Greg
  20. try Samco hoses - they are silicon and can be made to length and shape https://samcosport.com/car/
  21. I’m looking for a radiator for our scargo, damaged is ok providing the bottom tank is ok many thanks
  22. Hi all, I am the third owner of my 1994 Nissan Altima. I'm looking to get some help and advice on repairs that it needs. Can somebody point me in the right direction to which forum I would use I don't really see a Nissan Altima forum. Alternatively I could just say what's wrong with it here. I need to swap out the knock sensor and I'm not really sure how to get to it. If anybody knows the procedure I would be grateful. The knock sensor is behind the engine below the intake manifold.
  23. Hi all, I’m trying to replace the alternator on my 2017 Nissan Micra K14 Visia 1.0L (71PS – HR10DE engine), but I’ve hit a wall trying to get the belt off. I’ve located the tensioner pulley (the black one just above the alternator), but the centre is smooth — no bolt head or nut — and I can’t for the life of me find where to apply a tool to release the belt tension. I am no mechanic either .... wheels and fluids is usually my limit! I’ve checked above, behind, and around the tensioner pulley but can’t see a square hole or hex boss to rotate the tensioner arm. The engine bay is tight, and I’m not sure if I’m missing something obvious or if access is just that hidden. I’ve tried to follow online guides and videos, but most are for different engines or older models (K12/K13). Photos attached if that helps (can add more if needed). Any help — diagrams, tips, tooling advice — would be massively appreciated before I lose the will to live or call a mechanic 😅 Thanks in advance!
  24. Hi there, I have a 2022 Nissan Qashqai J12 Tekna (36 CAM, etc.), and my current display screen looks like this: [img]https://i.ibb.co/ZR3WXYr2/Screenshot-2025-06-19-at-11-48-41-Used-2022-BLUE-Nissan-Qashqai-1-3-Di-G-T-MH-158-Tekna-5dr-Xtronic.png[/img] I’m looking to upgrade it to this screen: [img]https://i.ibb.co/xZpfPGP/Screenshot-2025-06-19-at-11-48-30-Used-2022-GREY-Nissan-Qashqai-1-3-Di-G-T-MH-158-Tekna-5dr-Xtronic.png[/img] Can you confirm the following: Is this a direct plug-and-play swap? Will all existing cameras and sensors still function correctly? Is a PIN code or any additional programming required? Thanks in advance for your help! Best regards,
  25. thanks admin. I'll take some pics, and post later. Any views on the 1.2 engines?
  26. Welcome to the Club
  27. You should be able to find a set of halogen headlamps which are completely different to Xenon type Try Partsfinder or eBay to see if there is a pair for sale
  28. Hi folks. Im new to this, but im trying desperately to sell my 1989 silver nissan sunny. She's in good condition and has been garaged for 10 yrs. Iv had it from New, so one owner. She needs a service,MOT and taxed⁷. She's nearly 40yrs old and the milage is 130,000... shes an old lady with plenty of life her still. Thanks for readying my story.
  29. Hi all Had my 2015 qashqai tekna over a year now with 49000 miles and 1 garage vist for a snapped coil spring.lol
  30. Does anyone on here have one of these & want to tell me all about it please ??
