- Service on Maidstone
Hi from ireland
P0356 error code
O7 nissan pulsar evaporater
- Leaking sunroof drain
Hi, thanks for letting me join the group. I have a 2010 Nissan note and I am having problems resetting the oil service light. When I try to reset as per the manual nothing happens. The spanner symbol is flashing and the zero as soon as the ignition is switched on. Also the when pushing the right hand trip button the clock will not adjust.- Earlier
- Navara 2021
- Hello From italy
Ciao Riki Enjoy the Xtrail my friend. Happy new year! - Leaking sunroof drain
