  2. Guys can you help love my pathy , got an issue. Thing over heats had head gasket done but points to possible cracked head is this fixable , or is it something else I’ve got a intercooler fitted ??? also back end classic has hole in it where is the best place or reliable mechanic who can work on this in the northants area help me
  4. So, a little update on ours! We've managed to get a warranty replacement agreed via Ancaster and Nissan UK. We had to prove service history and it's going to take 6-8 weeks because there's a part out of stock (they've already had it 6 weeks). It took some arguing but definitely worth pursuing, especially if you've maintained your vehicle.
  5. Thanks. No instruction hadn't changed anything. Just did reset when it stopped working.
  6. Sounds like you have sorted it then - well done! You have done all the checks in the correct way and come to the right conclusion Only other thing maybe to recode the throttle body which was a thing on the slightly older Micra but may still apply A good scan tool should have this function on it
  7. You could try using different protocol settings on the scanners (if available) to read the codes
  8. Earlier
  9. You may be able to get the spheres re-gassed.....you could do on the Citroen and Hydrolastic spheres many years ago - look up Sphere repairs or regas
  10. Hi Stuart....welcome to the club I would say just have the vehicle checked over at a garage and if it is in need of a service to then have this carried out before venturing abroad. Also check your tyres for wear or damage and make sure all your lights are in working order. You may need to get vehicle passes such as Vignettes but otherwise, convert your headlamps so that the beam is deflected to the other side (can get a kit from Halfords for that). Good luck and enjoy your trip
  11. Sorry that no one responded to your post. One of the reasons on the old Micra 4 cylinder engine for poor idle was carbon build up in the throttle body. When it is cleaned out and refitted, you would then have to perform a reset on it through a diagnostic scan tool which should sort it
  12. When I had this i thought it was a phone or car setting. Can't really remember but I did get it to stop by altering which ever setting it was.
  13. The truck has been sold.
  14. My son is the proud new owner of a 2006 X-Trail T-30 as his first vehicle. Generally, it's in great condition, but it does need some bodywork to deal with rust. We are seeking recommendations on where to look online for replacement parts, ideally in Canada but open to internal suggestions. Specifically: Left Quarter Extension Left Quarter Reinforcement Thank you in advance for any advice or experiences.
  15. Firstly thanks to admin et all for the inclusion of your forum ...... Had a Navara some years back ... dreaded chassis issue and managed a buy back from Nissan Nordics as I live in Sweden. .. Just bought a 2018 NV300 and am trying to remove the drivers arm rest to fit an aftermarket seat cover... centre cap removed and a plastic long squared centre piece revealed.... any clue on how to remove please?... Have put grips on it and tried to ease it free and even put a shifter on it to hopefully slacken it off .... but to to avail ....any one had any experience with this that they could pass on valuable info? Thank you in advance Dox
  16. I would suspect it is the brake pads moving backwards and forwards - usually happens if the pads fitting kit is missing and allows the pads to move in the carrier. If it was the driveshaft joint then it would be constantly be clicking on acceleration and deceleration
  17. Did you resolve the issue? I was thinking it may be the Dual Mass Flywheel (if manual transmission) starting to break up Usually noticeable when switching the engine on/off when it will start to rattle
  18. a quick search with Google Lens reveals some results Just right click over the image above and select search with Google Lens and it brings up results of products that roughly match the clips you're looking for
  19. So, here's the saga. Offside Drum collapsed inside, my fault- long story. Anyway, new drums, studs, bearings, shoes, spring kit purchased, but could I find an ABS ring for the pixo anywhere? Nope! Eventually, Vertu Nissan offered me 2 rings for £201!!! Bought 2 used drums, cleaned/painted and fitted. ABS light turned off 👍 Moral of the story: Parts like this are becoming very difficult to get. Also, does anyone have any ABS rings? I have 2 brand new drums, with new bearings pressed in and ready to. They'll need the fings fitted, obviously. You can have them both for £50 plus whatever the p&p will be Tony
      • 1
      • Like
  20. occasionally i get a noise from the o/s/r of my car and a red warning light flashes briefly on the dash(i think it is a master warning light) .After a second the light and noise disappear and everything is ok. Performance and braking are not affected . The noise sounds a bit like ABS Working . Had rear pads replaced and a recent Mot all ok. Noise returned briefly a couple of days ago again just for a second .Usually happens on or near a corner .Any ideas???
  21. Hi, my mum has a 2005 Micra, she doesn’t want to sell it, ever. It has c40k mileage and drives like a dream! But, the tailgate switch has failed and I’m struggling to get a replacement - it’s the intelligent key version - part number 25380AX10B. Any ideas please?? There loads of the 25380AX60B but these aren’t compatible with the intelligent key. Thanks in anticipation!
  22. Hi, my mum has a 2005 Micra, she doesn’t want to sell it, ever. It has c40k mileage and drives like a dream! But, the tailgate switch has failed and I’m struggling to get a replacement - it’s the intelligent key version - part number 25380AX10B. Any ideas please?? There loads of the 25380AX60B but these aren’t compatible with the intelligent key. Thanks in anticipation!
  23. Hi, welcome to the Club Good to have you onboard!
  24. you could try running it through Google Lens which may identify the model
  25. I recently got a 2019 Tekna which I'm finding is very "jittery" at low speeds, particularly when cold. Anyone else finding the sane?
  26. Hi everyone I have a 58 plate d40 and have bought a canopy for it my question is how does the mountain top come off my d40 to fit the canopy please. Scot
  27. Hi....and welcome to the Club
