  2. bkb
    Engine Swap
  3. have wheel extenders and wondering who knows where i can get arch extenders for mot clearance , pain having to remove the spacers once a year
  4. Seems like the connections may be the wrong way round (possibly?)
  5. Has anything dropped into the heater motor from the dashboard vents by the screen? Also, remove the cabin filter and see if the vents have dragged anything into the blower motor through there
  6. I would definitely start with the glovebox which should then give you a better view of the heater motor and resistor pack
  7. There are several methods to gain entry without damage....although never really tried any of them One is using half a tennis ball over the lock but can't see how that would work Bent coat hanger is probably the best method ..... have a look on YouTube for any instructional videos
  8. I would take it back to the dealer immediately for a check on the software. Seem to recall reading there is an issue on this system
  9. Hi....welcome to the Forums Good to have you onboard!
  10. Hi - can anyone tell me if part number 4911050N11 will work as the OEM part number is 4911050M11 thanks Craig
  11. Last week
  12. how did you get on with it? I can imagine it was a pig of a job to remove the door lock latch mechanism
  13. Sorry, not a clue but please do let us know how you get on with it
  14. Will check Will check
  15. Possibly some air in the fuel filter .... if it has a priming rubber bulb then this should be firm at all times, if it needs pumping up then you have air trapped in there.
  16. Thanks for sharing the solution for this issue....pretty sure other members may have suffered this one and taken to the dealers for an expensive reset
  17. Earlier
  18. Thanks for replying. new clutch in, it had already been making sound for sometime so just did it rather then waiting for it to completely!
  19. The connector that came with the pathfinder has 5 wires but all the electric brake modules have 4 wire connections. which wires get doubled up?
  20. Hi, I live in Australia and am considering buying a Navara as an upgrade on our VW Golf for bigger space and the ability to do some gentle 4WD. We will not be doing any crazy 4WD, just a little to get us to places we cant currently access in our Golf. I have had a quick test drive of a 2018 Navara ST-X 4x4 and I like the tech and smooth drive, it is definitely better than other "utes" as they call them here, BUT, and its quite a big but a lot of people in Australia seem to really hate them so I was wondering what actual current owners opinions are? Would you buy the D23 Navara again if you could go back in time? Has anyone had to have any major repair work done and if so after how many kms? I also watched this and it seems like a fairly balanced review and it recommends the Navara for how I would use it All opinions and comments welcome Many thanks
  21. I currently have a solid aluminium rear cover with roof bars on my Tekna 2017. I want to swap to a black roller also with roof bars. Anyone want to swap?
  22. I recently heard a rattling coming from the front of my 2016 note & discovered the bonnet 'stay' to have come loose from its clip on the bonnet. Put tape around stay but its come adrift again.
  23. Try BluePrint for one, they should have something listed
  24. Best to read the small print on their website or paperwork and let us know how you get on
  25. I wonder if you should take it to another garage - one that specialises in four wheel alignment The suspension should always first be adjusted from the rear (if there is adjustment possible) otherwise I can't see what the issue is (accident damage aside)
  26. Try this site....should have your car listed https://www.castrol.com/en_gb/united-kingdom/home/car-engine-oil-and-fluids/motor-oil-and-fluids-finder.html
  27. I've got the same issue. The dealer said the car is designed that way.
  28. hi all , just blown my engine on my nissan navara d40 2007 ( gutted ) main dealer wants a lot of money to replace same anyone know where i can get a good second hand engine one
