have wheel extenders and wondering who knows where i can get arch extenders for mot clearance , pain having to remove the spacers once a year
K11 Micra Coil pack Rev gauge install issue
Trevor replied to MrMiles's topic in Micra Club's Topics
Seems like the connections may be the wrong way round (possibly?) -
Has anything dropped into the heater motor from the dashboard vents by the screen? Also, remove the cabin filter and see if the vents have dragged anything into the blower motor through there
I would definitely start with the glovebox which should then give you a better view of the heater motor and resistor pack
There are several methods to gain entry without damage....although never really tried any of them One is using half a tennis ball over the lock but can't see how that would work Bent coat hanger is probably the best method ..... have a look on YouTube for any instructional videos
I would take it back to the dealer immediately for a check on the software. Seem to recall reading there is an issue on this system
Hi....welcome to the Forums Good to have you onboard!
Hi - can anyone tell me if part number 4911050N11 will work as the OEM part number is 4911050M11 thanks Craig
Deleted factory data from leaf system diagnose menu
Sorry, not a clue but please do let us know how you get on with it - Earlier
Possibly some air in the fuel filter .... if it has a priming rubber bulb then this should be firm at all times, if it needs pumping up then you have air trapped in there.
Nissan x trail 1600 2017 model disel
Trevor replied to Richard dack's topic in General Nissan Owners Lounge
Thanks for sharing the solution for this issue....pretty sure other members may have suffered this one and taken to the dealers for an expensive reset -
Thanks for replying. new clutch in, it had already been making sound for sometime so just did it rather then waiting for it to completely!
I recently heard a rattling coming from the front of my 2016 note & discovered the bonnet 'stay' to have come loose from its clip on the bonnet. Put tape around stay but its come adrift again. -
Nissan Roadside Assistance Cover
