PepMcb joined the community
nytess18 joined the community
Luxxe joined the community
rouge189 joined the community
amaracho joined the community
Serena joined the community
Sorry, have double posted š
HI everyone, I wanted to let people know about my first "breakdown" and to warn others of recall notices done while at the garage. I will have owned the car 3 weeks on Friday and having done only just over 200 miles (most of which was to Newcastle airport and back home). We came back home to airport after week away in Austria to find car wouldn't let me in? Thought maybe key fob was flat, so took skeleton key and opened drivers door manually. Once inside vehicle I still couldn't open remaining doors or boot. Tried to start car but no sign of life. Battery looked dead to me. Vehicle comes with RAC cover for first year, so called number and (without boring people with details of automated systems) the RAC Agreed to send technician to help with starting vehicle. The RAC technician checked systems over, put boost on battery and we were able to open remaining doors and start the engine. With the engine running carried out several checks before deciding that the battery needed to be replaced as not holding any charge. I contacted the dealer who said they would re-imburse cost of replacement battery if I needed one fitting. As it turned out the RAC technician didn't have a battery, or was able to obtain one on a Saturday afternoon. Luckily he was able just to put some charge in vehicle and advise us to drive straight home without stopping (as money would have been wasted and not re-imbursed) if he had fitted a new battery. The car made it home later on Saturday afternoon and back to garage first thing on Monday morning. Due to number of service bookings and other jobs, I spent the morning at garage waiting for inspection and repairs. I had expected the battery just to be replaced but when technician checked condition, battery was found okay, just flat and needing a full charge. I was told that the car had been the subject of two recalls since purchase and that both (one more than other) would drain vehicle battery when car stood for a few days, like not being used over the weekend. The two recalls were PG4CH -- Alarm and PG5C0 Combimeter - 12v Battery. Both had faults in them that resulted in both systems not shutting down when car stopped, hence drain on battery while stood. The combimeter was seen as the one that drained the most battery power. Both were software issues that needed to be downloaded and updated in vehicle. Took over two hours more to carryout recall work and update the software but battery then retested and given a clean bill of health. Something that has never happed to me in over 40 years of leaving cars at airports but always a first time. Time at the garage was more than expected but cannot expect to jump que over people who had own vehicles booked into garage. Hopefully this will be the first and last breakdown we have with the vehicle. We love the car, how it drives and how comfortable to drive. Regards, Trevor
Hi all, might sound like a mid life crisis but I brought a 1986 Nissan sunny 1.3 petrol, I love it and I would like just a bit more power. its only done 42k the engine sound very healthy and Iād like to add an exhaust and intake filter. i would also like to know if there is anything else I can do eg change or tune the carb? I have a set of lowering springs in the post (35mm) and I will be getting some nice wheels also very soon. so it will handle slightly less boat like and sound fruity. im struggling to find information on what can be done to my sunny but then it is nearly 40 yr old lol so any help would be great or links to parts I can buy many thanks jaff
Good afternoon, the wifeās qashqai is in garage for what sounds like CV noise. I bought two drive shafts from AUTODOC as the garage couldnāt get hold of any. The offside drive shaft has fitted ok but the n/s doesnāt fit. The new one has 26 teeth differential side but the old one has 27 teeth. Can anyone shed any light or wisdom on this please. It is a 2019 1.5 dci N conecta.
Or off road trips near me?
Hi all I have a 2011 Spanish built truck thatās being difficult at the moment. While driving it will lose complete power as seen in the video but I can turn it off and on and it will temporarily fix the problem. Itās the model with the electric waste gate and I have replaced as many sensors as I can find and Iāve also replaced the injectors and waste gate it self. As you can see thereās no warning lights on the dash or codes on the reader. https://drive.google.com/file/d/1d8qYl_jnsE9DAU_9R3ntDzCkfwC4Oz33/view?usp=drivesdk https://drive.google.com/file/d/11e5PCfRGUoEeQnFnB0VEUwoW9hifNtm2/view?usp=drivesdk anyone struck this problem? cheers Lucas
Please please help! Everytime I start the car, Spotify automatically starts playing. Iāve spoken with Apple and Vodafone and they say itās a car setting. Iāve just spoken to the Nissan dealership and they said ā⦠they all do it, even our courtesy carsā! There must be a fix, this is the only car Iāve ever had that does this, very frustrating. Any help appreciated TIA
Hi all! šš» I'm currently having a massive issues with my micra k13 2013 acenta. The internal heater blower only lets through a teeny tiny amount of air. So far we have tried: Checking fuses and relays all are working - still the same Replaced pollen filter - still the same Replacing resistor with 2 other ones - still the same Replacing the heater blower fan by taking the whole front dash out (not fun!) - still the same When standing outside the car and the fans are switched to an on position you can hear the noise like the fans are on inside the cab but still a teeny tiny amount of air is coming through. What else could it be as we are at our wits end. Any suggestions are welcome please š š Thank you for taking the time to read this, it is very much appreciated
Iām looking to buy a replacement wheel for my Micra Special Edition 25. As you can see in the photo itās an 8 spoke alloy and 175/60R15. Could anyone advise where to get one from please? Thanks in advance!
