SPJW joined the community
- Hello
- Hello
Rbev started following Electrical issues, center console backlighting
Rbev joined the community
car won't start
nissan micra 2014 the ignition lights up when i turn the key but when I turn to start it won't start. Also, as soon as I turn it on the radiator fan comes up although the engine is cold. The battery is ok. I drove the car all day, today, and after parked for a couple of hours this happened.
Carlos joined the community
Genus9 joined the community
Reverse camera issue
MikeC joined the community
Juke owner says hi
Juke owner says hi
Leaf Slow Charging Issues
