LB580 joined the community
Peter Ellison joined the community
seun joined the community
Am I correct in thinking that a pulsar with no factory fitted 360 or reversing camera (2015) can NOT have the steering wheel controls function with a Chinese android aftermarket head unit ? - it came with 2 canbus and 3 harnesses - 1 fits and works , 1 has the 2 connectors but one of them is too small but works when fitted , and the 3rd basic one has no canbus and not 1 white plug but works pretty much the same except for spatial adjustment ( fixed as centre for sound )
- Hi from ireland
Pasquale joined the community
Lamonta333 joined the community
Cheers Steve for that,has put my mind at ease a bit got the car booked in on Thursday for them to check it out let you know the outcome
BizChuck joined the community
My led headlight has a malfunction, I've only had my car for eight months and I've got two years warranty on it should this be covered for repair
russty joined the community
Navara 2021
- Timing chain slipped
Trevor started following New owner of a 2023 juke , Timing chain slipped , Issue with 2014 Nissan Note Boot Lock and 4 others
Nissan Serena
K14_CVT joined the community
Strange electrical issues
Looking forward to being a owner of a 2023 juke
