  2. Morning all! I'm looking at replacing my disc and pads on my nissan pulsar. Could I ask if anyone has a pdf workshop manual or one they would recommend for changing brake disc and pads on a MK3 (2016) Nissan Pulsar?
  4. Afternoon all! I'm looking at replacing my disc and pads on my nissan pulsar. Could I ask if anyone has a pdf workshop manual or one they would recommend for changing brake disc and pads on a MK3 (2016) Nissan Pulsar?
  6. Hello , it has been awhile since last posting a/c stoped chilling and garage found small leak and sorted. But fitter said that the main radiator fan was not coming on and could cause problems with high temp /pressure in a/c system.cannot find anything about checking fan motor. Not a lot of space to access it . Does the fan have a fuse?
  7. Earlier
  8. Sorry, have double posted šŸ˜„
  9. Hi all just purchased a 2021 leaf and given it my first charge it was at Lidl at .74 per kw charged from 20 - 95% took 58 minutes and the total cost was £15-74p how does the kw work out? also does anyone use the granny charger only thanks for any help !
  10. Hello there, As a newb to the world of Nissan motoring, I wonder if someone can help? We have just taken delivery of a new 2025 X-Trail Accenta Premium e-power and have been driving it for a few days, and have been puzzling over how the front-parking sensor is supposed to work. Coming home at the end of a journey and driving up to our garage door the front door parking sensor fails to activate. Stopping the car, putting it into neutral and then drive again seems to activate the front sensor, and it starts pinging. Are we doing something wrong, something wrongly configured, or is this normal behaviour for the car? Thanks in advance for any replies :) Sok.
  11. good morning , would anyone know the name / part number of this corner piece of rubber for the windscreen and where I could source one from please. it has gone missing on the left hand side. thank you in advance for any help / advice cheers, nick
  12. i've just purchaced a used 2018 Qashqai. It has a 1.2-litre engine. This is the smallest engine I have ever had in my previous cars. But must admit it drove well on my test drive, and is in excellent nick, body & interior, so decided to get it. But just have this nagging doubt in my head about the engine, will it last as well as other larger engines? Although I see it has a timing chain (not belt). I guess that's a plus. Will look forward to reading through the posts on here. Cheers Bob
  13. x2 Brake Clutch Pedal Rubber Pads cover that fits NISSAN Qashqai Juke X-Trail II Sold by: NonStop_Auto Ebay Seller. Same item fits Nissan Note Tekna 2014 E12 I replaced today 06.06.2025
  14. Parking sensor?
  15. Anyone know what this relates to
  16. Recently bought a Micra K12 for my daughter to learn to drive, With any car I have bought I always give the car a full service replacing all fluids, Plugs, Belts etc. I normally will use OE parts and fluids. I was originally quoted £51 for 3lts of gearbox oil (Nissan MT-XZ Gearbox 75W-80 KE91699935) but when stock had arrived was told it was a mistake and it was £105 (KE91699071) (£105 seems way too much for 3ltrs of oil) I was looking at GSF, Eurocarparts and Halfords. Getting a lot of conflicting recommended oils (75w80 or 75w85 Gl-4 I think is the recommended oil, no mention of synthetic or mineral) Comma's and GSF recommends - EP75W80 Plus (Mineral) Halfords recommends - Comma Gear Oil SX75w/90 GL-4 (Part Synthetic) Wrong Grade? I noticed Comma Fully Synthetic MVMTF 75W80 Plus GL-4 lists under compatibiliy suitable for Nissan MT-XZ, Nissan MT-XZ TL (JR Type) but no website lists it as compatible. Can anyone confirm which ones would be suitable or could recommend another brand? Many thanks in advance
  17. Hi all, might sound like a mid life crisis but I brought a 1986 Nissan sunny 1.3 petrol, I love it and I would like just a bit more power. its only done 42k the engine sound very healthy and I’d like to add an exhaust and intake filter. i would also like to know if there is anything else I can do eg change or tune the carb? I have a set of lowering springs in the post (35mm) and I will be getting some nice wheels also very soon. so it will handle slightly less boat like and sound fruity. im struggling to find information on what can be done to my sunny but then it is nearly 40 yr old lol so any help would be great or links to parts I can buy many thanks jaff
  18. I guess you could swap the inner joint for the original one that will fit the gearbox, as a last resort?
  19. Good afternoon, the wife’s qashqai is in garage for what sounds like CV noise. I bought two drive shafts from AUTODOC as the garage couldn’t get hold of any. The offside drive shaft has fitted ok but the n/s doesn’t fit. The new one has 26 teeth differential side but the old one has 27 teeth. Can anyone shed any light or wisdom on this please. It is a 2019 1.5 dci N conecta.
  20. Or off road trips near me?
  21. Hi all I have a 2011 Spanish built truck that’s being difficult at the moment. While driving it will lose complete power as seen in the video but I can turn it off and on and it will temporarily fix the problem. It’s the model with the electric waste gate and I have replaced as many sensors as I can find and I’ve also replaced the injectors and waste gate it self. As you can see there’s no warning lights on the dash or codes on the reader. https://drive.google.com/file/d/1d8qYl_jnsE9DAU_9R3ntDzCkfwC4Oz33/view?usp=drivesdk https://drive.google.com/file/d/11e5PCfRGUoEeQnFnB0VEUwoW9hifNtm2/view?usp=drivesdk anyone struck this problem? cheers Lucas
  22. Please please help! Everytime I start the car, Spotify automatically starts playing. I’ve spoken with Apple and Vodafone and they say it’s a car setting. I’ve just spoken to the Nissan dealership and they said ā€œā€¦ they all do it, even our courtesy carsā€! There must be a fix, this is the only car I’ve ever had that does this, very frustrating. Any help appreciated TIA
  23. Hello everyone Guys I am desperate. I can't find the engine number in any way. Can you help me? Owner of a Pulsar dci diesel Thank you guys
  24. Hi all! šŸ‘‹šŸ» I'm currently having a massive issues with my micra k13 2013 acenta. The internal heater blower only lets through a teeny tiny amount of air. So far we have tried: Checking fuses and relays all are working - still the same Replaced pollen filter - still the same Replacing resistor with 2 other ones - still the same Replacing the heater blower fan by taking the whole front dash out (not fun!) - still the same When standing outside the car and the fans are switched to an on position you can hear the noise like the fans are on inside the cab but still a teeny tiny amount of air is coming through. What else could it be as we are at our wits end. Any suggestions are welcome please šŸ™ 😊 Thank you for taking the time to read this, it is very much appreciated
  25. I’m looking to buy a replacement wheel for my Micra Special Edition 25. As you can see in the photo it’s an 8 spoke alloy and 175/60R15. Could anyone advise where to get one from please? Thanks in advance!
  26. Just taking a sec to say Hello, Just bought a Nissan Micra K12 1.2 2008 for my daughter.
  27. Hello I am looking for a Nissan SD25 Diesil engine which is out of a Nissan 20 Forklift. I am told the same engine was used in Nissan Cabstar and Nissan Bluebird vehicles in the 1980s. Our currant engine has a hole in the block so I am looking for a good block or a complete engine. Many thanks Colin
  28. I would definitely advise to return the car to the garage who fitted the clutch for them to diagnose the issue - could be an adjustment required or a faulty part, etc?
  29. Just had a new clutch fitted to my 10 plate Pixo, all was good for about a week, now its quite hard and grinder when selecting a gear, mainly when down shifting and sometimes when shifting up. Suggestions would be greatly appreciated. Thanks guys
