Roger Smith started following New Members Introductions
Roger Smith started following Nissan Note service reset
Hi, thanks for letting me join the group. I have a 2010 Nissan note and I am having problems resetting the oil service light. When I try to reset as per the manual nothing happens. The spanner symbol is flashing and the zero as soon as the ignition is switched on. Also the when pushing the right hand trip button the clock will not adjust.
Roger Smith joined the community
Service on Maidstone
Hi Can anyone recommend a reliable garage in Maidstone to service my 2013 Qashqai? I just moved there so need some guidance. Thanks in advance.
LB580 joined the community
Peter Ellison joined the community
seun joined the community
Am I correct in thinking that a pulsar with no factory fitted 360 or reversing camera (2015) can NOT have the steering wheel controls function with a Chinese android aftermarket head unit ? - it came with 2 canbus and 3 harnesses - 1 fits and works , 1 has the 2 connectors but one of them is too small but works when fitted , and the 3rd basic one has no canbus and not 1 white plug but works pretty much the same except for spatial adjustment ( fixed as centre for sound )
- Hi from ireland
Pasquale joined the community
Lamonta333 joined the community
Cheers Steve for that,has put my mind at ease a bit got the car booked in on Thursday for them to check it out let you know the outcome
BizChuck joined the community
My led headlight has a malfunction, I've only had my car for eight months and I've got two years warranty on it should this be covered for repair
russty joined the community
Navara 2021
- Timing chain slipped
Trevor started following Nissan Serena , Timing chain slipped , Issue with 2014 Nissan Note Boot Lock and 3 others
Nissan Serena
New owner of a 2023 juke
K14_CVT joined the community
Strange electrical issues
