October 18, 20241 yr I have a NV300 from 2018 with 145 dci engine. Have the fault message on the display "Check anti pollution system" When I connect with OBD2 it says -fault value from Nox sensor "B" - I have changed the sensor and removed the faulty code but it still comes back. I can start the engine 3-4 times before it get back. Are there several Nox sensors or what does the "B" stand for? Any ideas?
November 8, 2024Nov 8 The NOX sensor B is measuring against NOX sensor A (B is usually behind A in the exhaust system) and if there is an exhaust leak then this could cause the issue
November 14, 2024Nov 14 Author Thanks Do you happened to have a link were I can purchase the "B" sensor? I can only find one type of Nox sensor for NV300.
November 27, 2024Nov 27 Maybe it is the same sensor part number if the lead is long enough to reach - that is assuming it has a B sensor.....if you do find another there, change the plugs over to the A sensor and see if the fault transfers to A sensor
