Just bought a K13 Micra auto with 80k on the odo.  The gearbox is smooth and shifts well but I've noticed when it shifts from 3rd to 4th at around 40mph I get that familiar rumble when the revs are too low for the gear.  The noise stays until I'm up around 45-50mph.  It makes it tricky in 40mph zones as I'm having to use the overdrive switch to shift the car back to 3rd.  Any tips?
Hi enzso ....welcome to the club
There is a reset procedure for the CVT transmission which may benefit you.
CM (Transmission Control Module) reset by cycling the ignition and pressing the accelerator pedal, or disconnecting the battery.
https://www.google.com/search?q=nissan+k13+automatic+gearbox+reset&rlz=1C5MACD_en&oq=nissan+k13+automatic+gearbox+reset&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRigAdIBCTE0NzQ0ajBqN6gCALACAA&sourceid=chrome&ie=UTF-8
There are also videos on how to reset the transmission in this search link (above)
