  2. Hello All, Hope everyone is doing well and keeping happy. Wondering if anyone can shed some light, have a late 2017 Nissan QQ 1.2 DIG-T. When you rev up the vehicle as the revs start to drop back down you can hear a single thud sound (sounds like hitting a bongo drum) please see video: https://www.qashqaiforums.co.uk/.https%3A//youtu.be/LfjeNubRFN8?si=MJzBz9LfQIPHRlbj Thank you very much
  3. Today
  4. Hey all, Hope life has been treating you well. I have an odd, So I have a Nissan QQ 1.2 dig 2017. I have noticed that when move off in reverse or set of forward you get a clicking noise from front driver side wheel (see video: https://youtu.be/btICZDUeN4E?si=Z_dPz4Ju8Nc86824 but it only does it once on the initial reverse set off or forward set off which would suggest it's not something getting caught. You can make it also do it, if you are in reverse gear, holding the brake and letting out the clutch pedal all whilst stationary Things done: I have inspected all suspension components. There is.in and out play in of drive shaft. 2) Checked.dog.bone mount. 3) checked for play in wheel / wheel bearing 4) check with wheel on for anything catching. If anyone has any ideas? Thank you
  5. Yesterday
  6. Hi everyone Just joined, so saying hi from sunny Brighton. I have recently purchased a Nissan Qashqai (2010) model and loving it so far jay316
  7. Last week
  8. Thank you yes haven’t given up yet as we really looked after our car so feel it is pretty unfair 🙃
  9. you could try running it through Google Lens which may identify the model
  10. I recently got a 2019 Tekna which I'm finding is very "jittery" at low speeds, particularly when cold. Anyone else finding the sane?
  11. Hi everyone I have a 58 plate d40 and have bought a canopy for it my question is how does the mountain top come off my d40 to fit the canopy please. Scot
  12. Hi....and welcome to the Club
  13. Earlier
  14. Certainly a cheap fix but should it be necessary on a new vehicle?
  15. Hi all. New-to-me owner here - an NP300 N-Guard - picked up 2 weeks ago and still getting to grips with it. Former owner of a T31 X-Trail for 11 years, so sticking with a known and (reasonably) well-trusted brand. Only after purchase and after a 200+ mile drive home did I realise that there was no 'key nut' for the lock-nuts on the tarmac-touching wheels, but a trip to the local dealer sorted that particular issue (at a cost, obviously). In putting the truck in to a local provider of underbody rust protection treatment yesterday. I learned that there was a security lock nut applied to the spare wheel too. Guess what? The key nut required for that, which attaches to a T-bar in the provided toolkit, wasn't anywhere to be found either, so the guy couldn't fully complete his treatment on the underside of the tub. I spoke to both previous owners of the vehicle, and neither could recall having seen nor had need to use that part (nor the key nut for the 'in-use' wheels. Too far down the line to know for sure if they weren't originally provided, or if someone's memory isn't what it should be. However, fact is, if I get a puncture and need to replace a wheel, I'm screwed until I get a key nut to drop the spare wheel. I called the local dealership after talking to the two previous owners. I explained my situation and, of course, a key nut is available to order (again, at cost), but as part of a set replacing the whole set-up, and removing the old part is, according to the parts guy, "tricky, but do-able". He added that the key nut would have to be part of a set 'cos the current lock nut would have a different design. Having looked online at images for the offending parts, it seems that the 'pattern' of the lock and key nuts are the same in every one, and this applies to D40 and NP300 models. Can anyone confirm if this is the case, please? If so, I can get a set off ebay for £20 less than Nissan are charging. Thanks in advance.
  16. I have a nissan qashqai j11 reversing problem. When I put in reverse and try to move the engine stop, it is a manual diesel stop start.
  17. Hi. If you need any help with insurance at all then please feel free to drop me a line. Regards, Dan.
  18. I'm having problems removing my wheels, having taken out the 4 wheel bolts the wheel seems to be stuck to the hub of the wheel. Any help please.
  19. I need new wiper blades for my 2020 K14 Micra because the current ones put smudges on my windshield. Please Give me some suggestions
  20. I have programmed fobs in the past and they have to be programmed at the same time rather than doing it later as it is opened for programming within the timeframe
  21. If it were me I would go over everything I have touched and ensure it is not damaged (as much as you can determine) and that there is nothing interfering with the component or wiring coming from it. This has worked many times for me when I have been in a rush and not noticed something simple
  22. It looks like a damper for the throttle, EGR or similar
  23. Hi Rob.....welcome to the club Good to have you onboard!
  24. Hi Sid....welcome to the Club The Sunny looks in amazing condition - so rare on the roads now Good to have you onboard
  25. I had the same problem radio cutting off there is a fee upgrade from nissan now work perfectly it's a common problem
  26. I own a 1.5dci Nissan pulsar 2015, and I want to change the CD player with a satnav unit. I was wondering if if anyone could help me find a wiring diagram for it as one of the original plugs doesn't fit into the new unit. I've had a look around and couldn't find one. Can anyone please help me?
  27. Hi enzso ....welcome to the club There is a reset procedure for the CVT transmission which may benefit you. CM (Transmission Control Module) reset by cycling the ignition and pressing the accelerator pedal, or disconnecting the battery. https://www.google.com/search?q=nissan+k13+automatic+gearbox+reset&rlz=1C5MACD_en&oq=nissan+k13+automatic+gearbox+reset&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRigAdIBCTE0NzQ0ajBqN6gCALACAA&sourceid=chrome&ie=UTF-8 There are also videos on how to reset the transmission in this search link (above)
  28. Does anyone know where to find rear right door glass for 1984 n11 4door cherry? Help please
  29. OK, I've managed to sort it now.
